Hello All,
I’m sure I have what must be a simple fault that has cropped up before.
I have a 2016 155ps rwd 2.2 MK8 transit tipper with 50,000 miles and serviced annually.
I suddenly lost power on a hill and started misfiring and blew a lot of oil from the top of the engine.
There a couple of fault codes relating to number 1 and 2 glow plugs.
Misfire is on number 1 injector.
Copper washers on the injectors have been changed along with the bolts and no change.
Turbo inspected and seems fine.
Oil cleaned from inside intake hoses and intercooler seems clear of oil.
The engine runs well although still missing on number 1 and blowing from the breather pipe which is currently disconnected.
Any ideas of what to check would be appreciated.
