Hi folks
I have fitted a set of steps to the rear doors which continually triggers the sensors when reversing. It's the type which bolts behind the tow ball with steps to each side. I've looked at the options using Forscan but I'm not sure if I can just turn off the centre 2 rear sensors leaving the corner ones. I've attached a pic with the current settings. Can anyone help?
