Front suspension height 350 vs 470
Postby Mbcltd » Tue Nov 15, 2022 6:32 pm
Hi all,
I have a 2020 350 l3, and have installed heavy duty rear springs,
Now she has quite a rake, so wondering if the 470 transit front struts are bigger/taller?
I know new transits have the option of a heavy duty front axle, but mot a clue what this entails or if it gives a higher ride height at the front?
Any help appreciated
Mbcltd
Re: Front suspension height 350 vs 470
Postby dumper » Tue Nov 15, 2022 7:02 pm
I can measure the front ride hight on my 460 x bus when it’s light if that’s any use .On my mk6 jumbo I fitted 470 struts springs and rear springs and dampers when I did it it weighed 28000 kgs as a part loaded camper and it lifted the rear 2 inches at the rear the front didn’t look much different maybe about a inch but I didn’t measure the front .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Mbcltd » Tue Nov 15, 2022 7:08 pm
dumper wrote:I can measure the front ride hight on my 460 x bus when it’s light if that’s any use .On my mk6 jumbo I fitted 470 struts springs and rear springs and dampers when I did it it weighed 28000 kgs as a part loaded camper and it lifted the rear 2 inches at the rear the front didn’t look much different maybe about a inch but I didn’t measure the front .
That would be much appreciated, thank you.
The standard rake on mine was quite alot, so I raised my front 40mm to level it out,
Done a camper conversion which now weighs 3000kg, so put 3+1 leafs on the back to beef it up due to the extra weight, and it's raised the back another 2.5 inches :roll:
So now need to raise the front again
Mbcltd
Postby dumper » Wed Nov 16, 2022 12:49 pm
Hi the hight is to the bottom of the wheel arch osf 30.5 nsf 30 osr & nsr are 30 inch on 195/75/16 tyres with a ruff weight of 32000 kgs hope this is of use .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Mbcltd » Wed Nov 16, 2022 10:20 pm
dumper wrote:Hi the hight is to the bottom of the wheel arch osf 30.5 nsf 30 osr & nsr are 30 inch on 195/75/16 tyres with a ruff weight of 32000 kgs hope this is of use .
Many thanks
Mbcltd
Postby dumper » Thu Nov 17, 2022 6:55 am
Cheers but i put one too many 0 s on the weight should be 3200 kgs.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Blizz » Fri Nov 18, 2022 9:51 am
Height measurements are always better if taken from center or edge of the wheel so differences on tire size/wear don't affect the measurements.
32000km! Thats a fat ass Transit!
Cheers,
David
Blizz
Postby dumper » Fri Nov 18, 2022 10:27 am
Yes I thought it was a truck :D as for ride hight when I’ve set up rally cars always done it that way as for the front it is on brand new tyres and the rear is on same tread depth .when I built my camper I made sure it stayed as near as possible to being equal on all 4 corners the same when I load it up the 1/2 difference on the front is due to adblue and diesel tanks are full .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
