if its anything like mine on the connect, there was a triangular bracket with it ...that bolts on and lets the cable hang from a position that is central to the wheel, it guides the cable down through a tube that is welded to the bracket.
this may be still bolted to your van
and there should also be another cable that acts as a safety strap
Having said all that, the parts diagram, if ive found the right one for mk8, does not show all those bits that are common to mine . so from the look of it, i may be wrong, you have all parts.
https://ford.7zap.com/en/transport/164/ ... 320/90226/all the best..mark
