Hi I just purchased a 2016 2ltr transit with no MOT. Checked all the lights pre MOT all fine. Arrived at test and nearside rear sidelight/indicator/brake lights inoperative so failed. Removed BCM checked for water ingress nothing DRY as a bone refitted and everything worked magic . Passed MOT collected it and nearside front dipped beam inopertive rears lights working fine. Now I have the nearside front indicator works when it wants daylight running works same as the indicator and the brake lights are the same yet the top brake light on the doors work fine, it gives the impression its a bad connection. They all work fine for 1-3-5 minutes then all fail then come back on and if I start the engine they all fail. I guess BCM having a mardy but cant find the same one as fitted to mine FAF can buy FAE FAK Is it possible to fit one of these and have ford reprogram it.
Thanks for any advise.
