Hi I’m new to the forum but hopefully someone can point me in the right direction. Mk8 2.2 17 seat minibus camper conversion, but nothing changed mechanically. 50k with decent history.
Started going into limp mode after 40 miles or so, no lights or prior warning, just cut out but would restart and work fine for a while, then do it again soemwhere between 40 and 100 miles later. Got worse over a few months and started to do it immediately after restarting. Been into garage who initially diagnosed faulty turbo actuator, with fault codes P2562-71 and 2563-00.
Swapped actuator for new and re built turbo. Fault came back after 30-40 miles, back in and new boost sensor fitted. Still got fault but now at around 100 miles+, would clear and come back about 100 miles further on, always in 6th gear and at 50-60mph.
Then it started to run rough just before it went into limp mode - noisier engine, loss of power and occasional “ticking” noise when lifting off the throttle. Would go into limp mode and restart ok, but still rough until it sat switched off for a while. Fuel economy became much worse when running rough. It then started to do it in 1st gear under load, such as a steep hill, and very occasionally on moderate throttle and lower speeds and gears. Van always starts ok but is really rough, noisy and hesitant on startup. No apparent smoke when driving. It sometimes hesitates and sometimes “coughs” but there isn’t any pattern to it. Occasionally got code for EGR being stuck open as well as above faults so taken for further investigation…
Ended up with new DPF, cat and vaporiser plus fuel filter. EGR all working ok. Full check over showed everything (injectors etc) working to correct parameters. Garage drove van back to back with another, only issue they could find was that on same van, at same speeds and route the other one showed much more variance on the turbo position - one was at 70%, whereas mine was around 30% at the same point.
So, back to turbo garage. Checked over again including MAF and intake MAP sensor compared to another identical van and all matched.
Turbo is free and seems fine.
The only issue is with the actuator - on the other van an example measurement - the “commanded boost actuator control bank” showed as 79%, and the “variable nozzle turbo position” was 79%, showing the commanded position was being achieved. On my van at the same throttle position the commanded was 0%, but the turbo position was 79%.
So the turbo is apparently working as it should, but the van doesn’t seem to be telling it to? It would them seem to make sense that the limp mode is actually caused by these measurements being vastly different.
This has left 2 garages stumped and me bankrupt with no clue where to go from here - is anyone able to assist?
