The van is a 2018 reg mk8 350 with a 2.0L 170bhp diesel engine (adblue). I bought it last year as a professional/coach-built camper conversion and have enjoyed a number of trouble free trips away with my wife up until last week when it just decided to not start...
The symptoms are:
Turn on the ignition and the dash lights up as normal with no warning lights/messages. Turn the key further to start and nothing happens other than an audible click from the dash but no error messages.
Things I have checked/tried:
Engine battery charged - ok
Battery connections - ok
Second key - same problem
Starter relay (in engine bay fuse box) - passed the 9v battery/multimeter test (eg clicked when connected to 9v battery and showed v low resistance on multimeter) - but I bought a new one just incase (same problem). Then I left starter relay out and shoved multimeter probes in relay power pin sockets and turned key - didn't register any voltage even though other relays in engine fusebox do when ignition on.
Fuses - checked virtually every fuse in the engine fuse box and the 2/3 fuse panels in the drivers footwell (and relevant relays). Also took the front seat out to access and check pre-fusebox fuses - all seemed ok, but..... whilst my owners manual fuse diagrams seem mostly accurate, the pre-fuse box seems to be missing a section of fuses/relays compared to the owners manual diagram. According to the manual this section should include amongst others: 2 ignition switch relay fuses plus the ignition relay itself (in total 7 relay and 12 fuses are just not there, there's just a space where the panel/sockets should be..??
The only other thing I can think of is there's a problem with the immobiliser, but I have no idea how to test for that.
Any suggestions would be very much appreciated.
Many thanks
