Hello, experts
This problem was originally posted on the Transit Custom board a while ago, but as it's a bit complicated to diagnose I was advised to ask here as well to benefit from your extensive knowledge and experience.
I have a 2013 left hand drive Tourneo Custom (L2H1) with motor code CYFF that has recently passed 240.000 kilometres.
Two years ago I had the right side driveshaft replaced because it made noises when turning hard to the left. When the job was done, I could feel a vibration in the car when the engine worked hard to convert force to speed. Typically in the second gear when exiting an intersection while applying pressure to the accelerator to gain speed. No explanation was found under the car, everything seemed as tight as it should be, so I just left it at that. It did not get worse during those two years, so I assumed no bearings were being eaten.
Three weeks ago I had the left hand side driveshaft replaced because it had for a long time been making noises when turning hard to the right. It turned out the rubber cover on the knuckle was gone, so no mystery as to the cause. But now I get a rather violent vibration when the engine applies force to the moving parts. It can't be good and I can almost feel that a major part of the horsepowers are wasted on making the vibration instead of turning the front wheels.
All included new parts were used, so everything should be nice and tight. The center nut at the end of the driveshaft was tightened to at least the recommended 250 newton, I've asked the mechanic.
Both driveshafts were made by the same vendor, supposedly new and marketed under the brand Triscan. They were purchased two years apart from a major supplier of aftermarket parts in my country, and the same brand is offered by several major suppliers here. It should hopefully mean the quality is good.
Since my original post, the car has been checked again by the mechanic who replaced both driveshafts and by a Ford garage. Neither of them can find any reason for the vibration and there is no unexpected room for movement at either end of the driveshafts.
Possibilities listed in the other board was clutch, gearbox or DMF (or wheelbearings), but replacing driveshafts should be a quite straightforward job and shouldn't likely cause any major damage to bearings or anything else. Right?
Does anyone have any theories on what could be the cause of the vibration? Any help is appreciated.
