Passenger side wing mirror indicator problem
Postby BoSelecta75 » Fri Oct 11, 2024 2:31 pm
Hi all - I have an MoT fail on left side repeater not working. This is the wing mirror repeater only, the repeaters in the front and rear light cluster are working fine. I suspect this could be related to the new passenger door I fitted after a run in with a bollard- the electric window (from drivers side), central locking etc are all fine on the door.
I’ve had the wiring loom connection apart in the door jam and cleaned up the pins but I’m at a loss and can’t find a wiring diagram to check for voltage. Any help much appreciated as I’m sure an auto electrician will have my eye balls out.
BoSelecta75
Re: Passenger side wing mirror indicator problem
Postby metalworker0 » Fri Oct 11, 2024 3:39 pm
Try swinging the door back and too, whilst the indicators are on..if they then work intermittently ..then its definitely a break in the wiring loom,
, I'd guess break in wiring in the loom where it comes out of the door post and into the door. as that's where the wires get continuously bent and flexed, which leads to failure.
see this video - this is a ford F150 ..so may be similar.
https://www.youtube.com/watch?v=pgpuSu4I1vc&t=873s
Don't know about testing with multimeter ..if they are not LED's ..then they will be 12 volt.
take the wires off at the nearest connection ..and just have the multimeter in continuity function with beep, the connection will probably be in the door somewhere..if its ok from there ..then you need to start testing the rest of the loom each side of the door ..may mean pulling wire protection or insulation off ..and spiking the wires with the probes.
BEMM manual is here somewhere this covers 2.2 and 2l ecoblue
https://www.manualslib.com/download/155 ... 16-75.html
the other main manual is here somewhere ..maybe ..cant remember ..you dont actually say if your is a 2.2 or 2l ecoblue .. so i cant even look for it ,.
here is the custom 2l ecioblue manual, may help somewhat ..mk8 2.2 not available or forgotten link cant find
https://www.mediafire.com/file/nrc1mse4 ... 2.zip/file
