Turbocharger Actuator
Postby Lee2121 » Wed Nov 12, 2025 2:07 pm
Hi
I need to replace the Turbocharger actuator which after watching a lot of YouTube video showing me the wrong location I'm now informed on my van it is attached to the turbo. Does anyone have any experience with replacing this and one thing i found online is that the ECU might need plugging into a computer after i have replaced the actuator, does anyone know if this is indeed the case?
My van is as follows.
Ford Transit 2025 (minibus) 2.2 diesel - 460 Trend H/R Bus 17 STR
Series: MK8 (V363)
123.3 BHP
Engine Code: USR6
Lee2121
Re: Turbocharger Actuator
Postby metalworker0 » Wed Nov 12, 2025 3:34 pm
they did not make a 2.2 in 2025
Postby Lee2121 » Wed Nov 12, 2025 3:35 pm
sorry typing mistake 2015 Year.
Lee2121
Postby metalworker0 » Wed Nov 12, 2025 4:08 pm
a quick search here, says they don't need calibrating .. i could be wrong
how to ID which one you need
https://www.ecutesting.com/product-cata ... tor-turbo/
and how do you know its the turbo actuator at fault when you're uncertain of identifying it
a lot of turbo boost leaks are down to the EGR
common form of actuator fail is stripped plastic gears within it .. this is something you don't find out with diagnostic software. well not unless you've spent a lot of time knowing how to interperate the results on many transits
Postby Lee2121 » Wed Nov 12, 2025 4:14 pm
thank you Mark.
I was told when the van went to a garage for diagnostics will be interesting to see when the actuator is changed if the problem will come back.
Lee2121
Postby Parastorm » Sat Nov 15, 2025 3:36 pm
yes they are all attached to the turbo, but the rear wheel drive is more complicated than the front wheel drive. the rear wheel drive involves removing the turbo as it is mounted underneath it and cannot be removed institute like it can on the FWD. after fitting it does need calibrating with diagnostic equipment.
Parastorm
Postby Lee2121 » Mon Nov 17, 2025 11:56 am
This is proving to be very tricky, i can now see and touch the actuator but looks like turbo needs to come off. does anyone have any links to a video maybe that shows the process as all of the video i can find are not for this version and the turbo seems to be in a much more accessible part of the engine than the version which i have.
Lee2121
Postby metalworker0 » Mon Nov 17, 2025 3:36 pm
Telling us if RWD of FWD, drive that would help with your answers
All i can tell you, in situations where it's bad access, that it sometimes helps to support engine, take mounts off .. and tilt engine .. take wheels off or remove wheel arch liners.
Postby Lee2121 » Mon Nov 17, 2025 5:01 pm
Sorry, it is rear wheel drive 17 seater bus.
thank you.
Lee2121
Postby bennetimo » Tue Mar 24, 2026 11:00 pm
Lee2121 wrote:This is proving to be very tricky, i can now see and touch the actuator but looks like turbo needs to come off. does anyone have any links to a video maybe that shows the process as all of the video i can find are not for this version and the turbo seems to be in a much more accessible part of the engine than the version which i have.
Hey, did you manage to get the actuator replaced without removing the turbo in the end? Curious as I need to replace the actuator on mine too. Also a MK8 RWD, and yeah all the videos I've seen are from slightly different variants where you can get to it really easily. Sods law I have the one that is more of a pain :roll:
bennetimo
