I have a check engine light on with a MAF sensor fault code. After further investigation the current sensor is clean and so is the air filter.
The engine bay has started filling with exhaust fumes so I'm suspecting a leak somewhere giving the MAF sensor a wrong reading and generating the code. I can't see any obvious leakage but the pipe in the photo is looking a bit suspect and wondered if that's the source of my problems.
From the photos does that seem a likely place for exhaust fumes leakage, and if so, what's the name of this part please?
Thanks!
