I'm shortly planning on replacing the clutch and flywheel on my 2015 2.2 RWD jumbo (MT82 manual gearbox).
Can anyone confirm whether the gearbox can be slid back enough on top of the subframe to access the clutch/flywheel without dropping the subframe, or does the subframe need to be dropped? If so, am I right in understanding that the rear subframe mounting bolts are very difficult to remove?
Want to know what I'm in for before I start.
Thanks!
