Hi, I have a 2.2 tdci rwd and just had to change the turbo so changed the fule and oil filter at the same time. Now when i start it it will run for a few seconds then start missing and smoking like mad. I have checked the fule to each injector and when i take off each pipe the engine cuts out. I have also bleed the fule pump. The engine isnt showing any faults on the odb.
Does anybody have any ideas?
Thank you
