Hi all,
Hoping someone might be able to help with a weird starting issue. Got a 2018 2.0 RWD that turns over for ages (approx 15-20 seconds) EVERY TIME before starting from cold, even when pumping accelerator. Eventually starts and runs perfectly and any subsequent starts while still warm or only been off for an hour or so it will start first time after the expected amount of time.
ForScan is showing me that it's flagged "P008A:21-2F Low Pressure Fuel System Pressure - Too Low". This is very intermittent though and when cleared does not appear every time the cold start issue occurs, it's somewhat random and maybe presents 30% of the time. It does not impact drivablility with no limp mode or noticeable hesitation.
My battery seems to be okay and I measure 12.5V under the bonnet between the positive terminal and jump point neutral.
I've replaced all 4 injectors in the last year for a separate issue, and checked they are all seated tightly and doesn't appear to be any leaking at fuel run off pipes or at base of injectors.
I have changed the fuel filter also in the last year and had the fuel tank dropped to add a feed for a diesel heater, so I've checked the filter housing and tank connections for leaks. I did notice one of the fuel line connectors that connects the pipes from the sender on the tank to the main line under the van looked like it had a coating of fuel on it. I disconnected it, checked the o-rings were intact and re-seated it, then cleaned it up. After a few runs it's looking a bit mucky again.
I have since replaced this elbow with a replacement that no longer leaks, and this has not made a difference to my issue. At the same time I also replaced my fuel filter (despite it being relatively new), the one I removed was still perfectly serviceable and clean, but put the new one in to be safe, unfortunately no joy.
Any advice would be greatly appreciated, and any information I can provide that would help I'm happy to do! Very frustrating having to sit there turning over the engine every day for the first time, I know it WILL start, it would just be nice to understand why and have it work as intended.
Cheers,
Josh
