Hi all.
I have a 2015 mk8 2.2 RWD, with twin batteries, no stop start enabled
I have no problems starting the van atm
The accessories battery has a resting voltage of 12.1, and drops further when under load, with engine off.
This was a national grid workshop van, that ran a small inverter from the accessories battery via the Customer Connection Point, and has after market wiring within the battery area as well.
Everything I've read says replace both batteries not just one.
I believe there is some form of voltage sensing relay in place, that is protecting the start battery from draining. So replacing the accessories battery only shouldn't be a problem
Has anyone got any experience or knowledge of this or a similar system?
Thanks Al
