A rather unwell Transit (DPF / limp mode)
Postby danp2 » Thu Sep 24, 2026 6:59 pm
Hi all!
As per my intro I drive minibuses at a school, and unfortunately one of them (a 2017 Transit 2.2) is currently off the road as it’s got the “service now”, “DPF filter full” type of errors and is in limp mode.
It did mainly short runs (as it’s not trusted on the motorway after breaking down twice) which obviously wouldn’t help, but has been looked at by several garages inc Ford but not been reliable in recent years.
It’s due back at the garage soon and in an attempt to avoid throwing good money after bad I thought I’d see if I can help the school at all.
Below is a selection of DTCs (there are 87) and screenshots from me using carscanner OBD tool.
I got some live data (can’t see how to post screenshots) but 256% DPF soot load % and 26 consecutive failed regens don’t sound great.
I’m not sure on the history as I’ve not been at the school that long but apparently they’ve had a DPF specialist look (and Ford as mentioned).
I don’t have the cables for Forscan but could probably get them plus access if it’s going to be revelatory.
I’ve looked at a few videos on YouTube and if it was my money it’d be going to a well respected DPF specialist to scan it with proper tools / clean out the DPF / clean out or replace vaporiser etc… so if there is one in the Hampshire area (or mobile) please shout!
Any advice welcomed! Thanks, Dan.
P2463 [0x2463]
Diesel particulate filter (DPF) - DPF restricted
Status: Confirmed
P246C [0x246C]
Diesel particulate filter (DPF) - DPF restricted, limp-home mode activated
Status: Confirmed
P2463(00) [0x246300]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
P246C(00) [0x246C00]
P006A(00) [0x006A00]
MAP sensor/MAF or VAF sensor bank 1 - correlation
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
P244B(00) [0x244B00]
Diesel particulate filter (DPF) - differential pressure too high
P1103(00) [0x110300]
MAF Sensor In Range But Higher Than Expected
P1102(00) [0x110200]
MAF Sensor In Range But Lower Than Expected
P007B(00) [0x007B00]
Turbocharger (TC) intercooler temperature sensor, bank 1 - circuit range/performance
P0111(00) [0x011100]
Intake air temperature (IAT) sensor - range/performance problem
IAT Circuit Range/Performance Problem
P0071(00) [0x007100]
Outside air temperature sensor - range/performance problem
P2539(00) [0x253900]
Fuel low pressure sensor - circuit malfunction
P0610(54) [0x061054]
Engine control module (ECM) - vehicle options error
P0683(00) [0x068300]
Glow plug control module to ECM/PCM communication error
P0420(00) [0x042000]
Catalytic converter system, bank 1 - efficiency below threshold
Catalyst System Efficiency Below Threshold (Bank 1)
P0299(00) [0x029900]
Turbocharger (TC)/supercharger (SC) - low boost
P0234(00) [0x023400]
Turbocharger (TC), engine boost condition - limit exceeded
Engine Overboost Condition
P0812(00) [0x081200]
Reverse gear - input circuit malfunction
P2002(00) [0x200200]
Particulate trap, bank 1 - efficiency below threshold
P064C(00) [0x064C00]
Glow plug control module - malfunction
P138B(00) [0x138B00]
GLOW PLUG CONTROL MODULE SYSTEM VOLTAGE
P0671(00) [0x067100]
Glow plug, cylinder 1 - circuit malfunction
P0672(00) [0x067200]
Glow plug, cylinder 2 - circuit malfunction
P0673(00) [0x067300]
Glow plug, cylinder 3 - circuit malfunction
P0674(00) [0x067400]
Glow plug, cylinder 4 - circuit malfunction
P06B9(00) [0x06B900]
Glow plug, cylinder 1 - circuit range/performance
P06BA(00) [0x06BA00]
Glow plug, cylinder 2 - circuit range/performance
P06BB(00) [0x06BB00]
Glow plug, cylinder 3 - circuit range/performance
P06BC(00) [0x06BC00]
Glow plug, cylinder 4 - circuit range/performance
danp2
Re: A rather unwell Transit (DPF / limp mode)
Postby metalworker0 » Thu Sep 24, 2026 7:54 pm
This number of DTCs means one thing only .. not enough voltage to make the systems work or batteries have been aloud to drain to a very low level.
Test the batteries .. 12.65 volts at a full charge
Do a drop test on the batteries
Remove positive and negative terminals .. clean with wire brush , including posts.
Check earths / grounds to body and engine .. take them off .. wire brush put them back
Finally check the charging system is charging - sort of 13.75 volts and above.
Clear all fault codes
Run engine and see what re-appears
Come back here with the list .. and we will see then what advice we can give you about antyy fault that reappears.
