Dome light won't turn on
Postby weldyrunner » Sat Oct 10, 2026 11:12 am
Hey,
I bought a used 2016 Mk8 which had already been DIY converted to a campervan (DIY). I realised later that the dome light in the front doesn't turn on, and I'm going crazy trying to figure it out.
Here's what I have so far:
- It doesn't work regardless of the switch position, even "always on".
- I bought a new bulb, but it didn't help. I tested it with a 9V battery to be safe, it works.
- I bought a new assembly and swapped it, didn't help either.
- I tested the fuses that I could find were relevant (F25 and F32 according to fuse-box.info, the drawings from Ford with my VIN don't show the right layout). Both are fine: they visually look OK, I tested for continuity and also no drop in voltage when in place.
So I took a look at the cables coming into the light assembly. There's 4: a positive, a ground, and 2 other cables that I figure are here to handle the door switch.
- The positive shows ~12V compared to chassis.
- The ground doesn't show continuity with the chassis.
- The other 2 cables show 0V and continuity to chassis.
I figured the ground was faulty, so I connected a cable from it straight to the chassis, but the light still doesn't work. So I tried a couple other things to troubleshoot the positive:
- I tested with the bulb between the fuse upstream and the chassis: turns on just fine.
- I checked the positive for voltage drop: sure enough I have 12V when the circuit is open, but 0V when I close it with the ground jumped to chassis. And I measure 12V between the positive of the assembly and the fuse.
So now I don't know what to do/check next. I don't know if the BCM is faulty or what to check for that.
weldyrunner
Re: Dome light won't turn on
Postby metalworker0 » Sat Oct 10, 2026 9:34 pm
sorry no idea
but went looking and asked google
Factory Cargo Lights: The factory overhead lights in a Ford Transit are tied to the BCM (Body Control Module) and will time out or trigger when doors open. Most converters either completely disconnect them from the factory loom and re-power them via the leisure battery with a manual switch, or replace them entirely with aftermarket LED kits
ME::: what if someone made a complete mess of this and somehow powered them from the doors,, the wires are known to fail where the loom passes into the door.
OR - if that light was meant to power another light .. that other light may be part of the circuit and the other light is at fault, not the one you are looking at
Postby noeljary » Mon Oct 12, 2026 1:15 am
Hi,
So because you're in a 2016 Transit, do you have a 2.2L or a 2.0L engine? That probably seems a strange question given we're talking about dome lights! But the electrical systems changed quite significantly at the same time.
I assume that as you've said DIY, we're talking a standard van body transit, rather than something built on top of a chassis cab?
And do you have footwell lights? If you do, do these come on e.g. when you open the doors?
If you can let me know I can pull up (hopefully) the right wiring diagram and we can start to see what's happening.
Regards
Noel
noeljary
Postby weldyrunner » Tue Oct 13, 2026 10:19 am
Thanks both for helping!
metalworker0:
It's possible it was messed up in the conversion, but from what I can see the circuitry looks original. It's the original light assembly above the driver's seat, and the cables behind it look like the original loom which go towards the A trim.
noeljary:
- It's the 2.2L engine. Worth noting the engine has been replaced before but I expect it was like for like - no sign of AdBlue cap that would have been needed for 2.0L.
- It's indeed the standard van body transit (L4H3 to be precise).
- I don't have footwell lights. There's really only that dome light above the front seats, if there were cargo lights before they're gone.
- For what it's worth, the indicator for door ajar works so it detects the doors correctly at least.
weldyrunner
Postby noeljary » Tue Oct 13, 2026 9:53 pm
Ok, so this should be the correct wiring diagram for your model transit - given 2016, assuming late model production seems reasonable.
Yes - it seems like the footwell lights are only a thing on the 2.0L models, but to be honest I don't remember them on mine either! You might have a glove box light though. If you do, and that works it will tell us something.
The key point though, is there is only a single 12V supply for all of the lights in the dome cluster, from F25 as you initially indicated. The grounds are switched either manually or through the BCM.
So, do you have just the one light in your cluster - or three, the central door with position switch, and the left/right 'map' lights?
Unfortunately Ford haven't really helped us by using two white/orange wires at the light cluster with different purposes. But for the purposes of the investigation, I think we should be focusing only on the manually switched on position (position 1) to start with and not the BCM controlled functions.
Can you confirm the voltage measured between pins C929A-1 and C929B-2. This should be 12V at all times, regardless of the switch position of any of the three lamps in the diagram.
I'm not quite sure what you mean about the indicator for door ajar working - as in the centre light in the cluster comes on with the switch in position 3 and a door open?
You mentioned in the first post that the ground doesn't show continuity with the chassis. If the light operates in door open mode (position 3) this would be because the GND is switched through the BCM, so makes the GD238 connection more suspect. With the battery disconnected, I'd measure the continuity again between C929B-2 and e.g. the cigarette lighter socket metal body. It should be virtually zero.
If you can let us know about those points, I think we'll be in a good place to figure this out. My suspicion right now is very much that main GND wire for manual light operation.
This part isn't relevant to your problems yet - but I think it's interesting, with the switch in position 2, the light is meant to be completely off - yet a GND option is still available through the BCM on C929C, so either they're using this to determine if the bulb is good, or the BCM could turn the light on even with the switch set to off!
Regards
Noel
noeljary
Postby weldyrunner » Wed Oct 14, 2026 5:18 pm
Hey Noel,
Thank you for the diagram, it's incredibly useful. I had actually mixed up which wires were which, so I could have kept spinning my wheels...
First, regarding the lights I have:
- I don't have a glove box light sadly, only the dome light.
- There's just one light in the cluster, no left/right map lights.
Second, to clarify what I meant about the door ajar indicator: what I meant is that the thing that detects if the door is opened works, because I see a message on the dashboard correctly. But you're right, that's only relevant for position 3. And the light doesn't operate in that mode either, so I'll leave that aside.
Now, to the matter at hand. I inspected the pins as instructed, and the problem seems to be with the positive cable (CB125) that comes from F25.
- Measuring between C929A-1 and C929B-2, I get 0V where I should have 12V.
- Testing continuity between C929A-1 and F25, I don't get a beep.
I confirmed that the rest is fine:
- Testing continuity between C929B-2 and the chassis, I get a beep as expected.
- Measuring between F25 and C929B-2, I get 12V as expected.
So something is broken between F25 and C929A-1... I checked higher up from the light assembly, I see a connector which could be C900 but the pins don't match. In any case, the cable continuity is fine between C929A-1 and that connector; and it's not between that connector and F25. So the problem must be higher up? What do you reckon, should I remove the trims to check?
As an aside, I inspected C929B-1 as well and it seems to be fine. I tested continuity between C929B-1 and C929B-2 and I get a beep when the door is opened which decays after some time when closed. That seems consistent with the BCM grounding that cable depending on the door with a timer, so all seems well there.
weldyrunner
Postby Altransit » Wed Oct 14, 2026 5:36 pm
Just out of interest, (and may be relevant), do any of your external lights come on when unlocking, or opening a door?
Postby noeljary » Wed Oct 14, 2026 7:25 pm
So good news in part! That at least seems fairly conclusive about an issue along the length somewhere of CB125.
As to the locations of connectors, Ford are a little, light on detail...
C900 is listed as 'Roof, front, RH side'
C311 is listed as 'Kickpanel, passenger side, top', but also 'A-Pillar LH'
Separately, because the full manual is quite piecemeal, they're listed as 'inline', which probably shouldn't come as a surprise.
So I'm writing this out as I'm going through the diagrams, and I have found a couple which I think will be more useful
This is the position of C311:
As I recall from my Transit, I've done some things with C0311 before (and on the 2.0L models, they just put a zero before the connector numbers), the easiest access to start with, before you have to start pulling whole bits of trim out is just to drop the glovebox to the floor - there are some clips at the top when opened. If you look towards the firewall, near the bottom of the A-pillar, you'll see a fairly large grey connector - the manuals indicate it has at least 57 positions, although not all are populated. If I recall, it may even have a blank handle that you use to separate the two parts. Being able to remove that connector without removing the trim may prove harder though, but it's really I think where you need to get to, so you can check if there is a voltage from F35 to pin 26. Hopefully you can confirm the wiring colours are roughly in the right place before committing!
There's another large connector in the vicinity, it's black, rectangular, and needs a bolt undone to disconnect it, I'm pretty sure from memory it's not this one - and likely only visible if you start removing trim.
This is the position of C900:
I've been in there previously to play with the microphone but I couldn't say with any certainty what's going on with the connectors up there. However, I'm looking into a different manual now, and concerned I may have given you something from a Transit Custom rather than full Transit. The fundamentals are really the same though. Except... the lower connector is called C311 in the diagram I gave you, it may be C300 in the Transit - but still pin 26, and the position information I've given you is still good.
Where it differs is the connector by the lights - in this case it may be called C9106 - in which case you're looking at pin 1.
In fact, this is the other diagram:
And in fact, looking up C9106, it has a location listed as 'Center of roof', which ties in more with what I'd expect. Looking at another diagram, they're likely very close and this is somewhat academic. Check the new pin number on the connector you found.
If you have found voltage at C300/C311, then with it disconnected, you'd want to check the resistance between there and the upper connector.
I'm not sure if I'm reading correctly in your last post about getting continuity for a time after the door closes. I assume you'd only get that with the battery connected - be very careful about continuity measurements with the battery connected, the readings you get may not be accurate and could potentially cause damage in e.g. the BCM, if you're on certain wires.
Anyway, hope that helps - I think it should let you pin down where the break/cut is!
Regards
Noel
noeljary
Postby weldyrunner » Thu Oct 15, 2026 5:32 pm
Hey Noel,
Ah yes, that second wiring diagram looks to match even more. The connector I saw upstream of the light assembly was indeed C9106, since all the pins numbers matched (but didn't with C900).
I will try to look further upstream to find C300 and test at that halfway point.
@Altransit: do you mean headlights, or another type of exterior light? I went to check: I get blinkers when unlocking, but nothing else when opening the door.
weldyrunner
Postby Altransit » Thu Oct 15, 2026 7:52 pm
weldyrunner wrote:@Altransit: do you mean headlights, or another type of exterior light? I went to check: I get blinkers when unlocking, but nothing else when opening the door.
Asking because my Euro5 Focus turns on the LED DLR's when you unlock the car (as well as the rear lights, and mirror downlights) and including all interior lights.
I'm wondering if it has had this feature turned off on the BCM config so as not to disturb the neighbours on a campsite every time the occupants come and go. It used to be a setting called "police dark mode" obviously for when the vehicle is used for surveillance, where entry lights wouldn't be welcome!
Just a thought, might be worth a look?
Postby weldyrunner » Sat Oct 17, 2026 12:40 am
Yes that's a good shout. I had considered "police mode" but it seemed unlikely: the blinkers still come on when I lock/unlock the van, and since I have a single interior light it would be just as easy to use the switch to turn it off.
But I got myself an OBDLink to use FORScan, so I will check too.
weldyrunner
Postby noeljary » Sat Oct 17, 2026 6:36 pm
Police Dark mode is absolutely a thing in the BCM - but just worth noting that it shouldn't be able to stop the dome light coming on with the switch in position 1. You could disconnect C929C-1 to confirm that if necessary, but I don't see how it could impact things.
noeljary
Postby Altransit » Sat Oct 17, 2026 7:05 pm
Has the dome light bulb been replaced with an LED?
Postby weldyrunner » Sun Oct 18, 2026 11:28 am
Yeah I agree with you Noel. I checked with FORScan and did not see police mode set.
Altransit it is an original bulb, not replaced by a LED.
weldyrunner
Postby Altransit » Sun Oct 18, 2026 5:24 pm
weldyrunner wrote:Yeah I agree with you Noel. I checked with FORScan and did not see police mode set.
Just asking because folk don't realise that LED's are polarity concious, and interior lights are reversed polarity, so won't work except with a filament bulb.
