speed limiter removal
Re: speed limiter removal
Postby martynx » Sat Nov 29, 2014 11:14 pm
Smartalec wrote:The speed limiter is not in the ECU its in the BCM (Body control Module) and this needs IDS to remove it.
Really ?? The "upper " 100mph limiter ?? I remove it without IDS & without touching the BCM!
martynx
Postby customal » Sun Nov 30, 2014 6:42 pm
Is it a secret or you going to let us know how to do it then ?
customal
Postby martynx » Sun Nov 30, 2014 7:12 pm
No secret , it's in the main engine controls flash memory that's all :) the PCM.
martynx
Postby obriencharlie123 » Mon Dec 01, 2014 12:13 am
How do you remove or who does it
Using Tapatalk
obriencharlie123
Postby martynx » Mon Dec 01, 2014 11:30 am
Most half decent tuners can do it I guess ?
martynx
Postby AllAboardTheWolfBus » Mon Dec 01, 2014 3:51 pm
Obviously one has to inform the insurance company that you've done this, but is this detectable by either Ford (warranty claims) or the insurance company in case of an accident?
AllAboardTheWolfBus
Postby Liliflower » Wed Dec 24, 2014 4:47 am
Liliflower
Postby paul2012 » Wed Dec 24, 2014 7:27 am
:shock: - They have used info I posted on this forum & my pics :evil:
From my original post here :arrow: viewtopic.php?f=54&t=143555&hilit#p1201465
IDS V86 will NOT remove speed limiters from Transit Custom it won't connect to PCM :!: Later software version is required.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby martynx » Wed Dec 24, 2014 7:40 am
The original poster wanted the 100mph limiter removed from a Transit Custom
The facebook link you posted describes a method for removing the lower limiters on Transit Connects
This lower limiter of 56/62/70 mph is handled differently by the vehicles Ecu's from the upper 100mph limiter & the 100mph can't currently be removed by an IDS tool be it genuine or clone , using the method described.
The only current method to remove a 100mph limiter on a Transit Custom is to open the Ecu & connect a boot flash tool like CMDflash to its PCB's Can-Bus , connecting also boot & test points via 1k ohm resistors, then after reading the Tricore processors boot password , read the correct IROM - You are then in possession of the program that runs the engine & this alone contains the upper 100mph limiter value & switching.
martynx
Postby mavericktc » Mon Feb 29, 2016 11:42 pm
Bump!
Is it still so freaking hard to remove the limiter?
My "loan" van is pulling way better then my old 140 mk7.5 and it reaches the limiter both on fifth and sixth gear withour any problem what so ever.
I want to go faster :evil:
mavericktc
Postby moley551 » Tue Mar 01, 2016 1:00 am
If and when I finally manage to master copying and pasting links.....I will start on the above instructions and infiltrate the tricore do dar in the quest for speed...don't hold your breath..... :?
"Don't find fault, find a remedy"
H. Ford
moley551
Postby moley551 » Tue Mar 01, 2016 9:34 am
Just an idea....has anyone removed the speed signal, some bikes had limiters fitted that could be defeated by removing the speed signal or emulating a lower one. It could be as simple as cutting the right wire.....a bit like bomb disposal!!!!!
H. Ford
moley551
Postby blueberrygreen » Tue Mar 01, 2016 8:12 pm
Your best bet for power upgrades is to badger gary from apt to get a proper tuning kit developed on his rolling road and his sport used as a guinea pig.
But I guess it's just if demand is there or not.
If enough people pm him then he might give it a go.
And figures would be provable on his rolling road.
Wonder if I can get ALS mapped in on a motec :lol:
blueberrygreen
Postby moley551 » Tue Mar 01, 2016 8:30 pm
Lost me... something about buggering Gary's guinea pig and pouring cold water over your head....... :lol: :lol: :lol:
H. Ford
moley551
Postby Mussels » Wed Mar 02, 2016 2:43 pm
moley551 wrote:Just an idea....has anyone removed the speed signal, some bikes had limiters fitted that could be defeated by removing the speed signal or emulating a lower one. It could be as simple as cutting the right wire.....a bit like bomb disposal!!!!!
It's probably taken off the ABS sensors so not such a good idea.
Mussels
Return to Transit Custom
