Cab dead locking
Cab dead locking
Postby neill » Wed Feb 14, 2018 12:26 am
Been testing my dead locks and noticed that although the lock/unlock button is deactivated after 60 seconds the drivers door handle on the inside still opens the door , Is that right . Thought that dead locking made opening doors impossible after smashing a window ?
neill
Re: Cab dead locking
Postby bigjohnthomas » Wed Feb 14, 2018 12:38 am
All is good
Perfect :)
bigjohnthomas
Postby neill » Wed Feb 14, 2018 11:01 pm
bigjohnthomas wrote:All is good
Perfect :)
So being able to open the door from inside is normal when dead locks are on?
This is not possible on my 2016 Mondeo or on any other deadlock vehicle I've owned. Thought the idea was that even if they smash a window they still can't get doors open !
neill
Postby Altransit » Wed Feb 14, 2018 11:04 pm
Are you getting in, shutting door and deadlocking with the fob, engine off :?:
Postby yasser » Thu Feb 15, 2018 7:58 am
You will be able to unlock the doors from the inside of any passenger area. This is a fail safe just in case the vehicle is in an accident or a fault occurs with you inside.
310 DCiV L2 Limited 155
yasser
Postby bigjohnthomas » Thu Feb 15, 2018 8:40 am
If there's a bulkhead. You can't get in the back from the front
And with the lock update you can't open the back from the front without the fob or somikn
bigjohnthomas
Postby bambi mk 1 » Thu Feb 15, 2018 9:05 am
bigjohnthomas wrote:If there's a bulkhead. You can't get in the back from the front
You can with the angle grinder option cant you :?: :P :mrgreen:
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
Postby bigjohnthomas » Thu Feb 15, 2018 10:03 am
:lol: wrong thread :oops:
bigjohnthomas
Postby neill » Fri Feb 16, 2018 12:05 am
Altransit wrote:Are you getting in, shutting door and deadlocking with the fob, engine off :?:
Yes , doing this , waiting for 60 seconds . The lock unlock button is deactivated as I'd expect but I'm able to open the drivers door , can't be correct
neill
Postby Altransit » Fri Feb 16, 2018 12:59 am
:idea: Does it, by chance, have sensors that know the fob is inside the vehicle :?:
Postby neill » Fri Feb 16, 2018 7:38 pm
Mm, that's a very good point ! I'm going to check it out . Thanks for that
neill
Return to Transit Custom
