My little project
My little project
Postby f74nk0 » Sun Oct 25, 2020 6:01 pm
Here is my 2016 face-lift custom hope you like not yet finsh yet waiting on some partsImageImageImage
Sent from my VOG-L29 using Tapatalk
f74nk0
Re: My little project
Postby Derv » Wed Oct 28, 2020 11:01 pm
Nice looking custom mate, what parts did you all need to facelift it? wouldn't mind doing that to my own van
Sent from my SM-N976B using Tapatalk
Derv
Postby f74nk0 » Thu Oct 29, 2020 6:33 am
Thanks mate i had to make fab and weld braket it was alot of work and the dash you need all of it and then you need to reprogram it
f74nk0
Postby Derv » Thu Oct 29, 2020 8:37 am
Nice job! Don't think I'd go as far as changing the dash as that sounds like a major task, but I'd like to do the front end conversion. What brackets need fabrication and what parts swap straight over? Did the drl headlights plug and play or did they also require programming?
Derv
Postby f74nk0 » Thu Oct 29, 2020 11:33 am
Lot of timing headlight top braket needs moveing
f74nk0
Postby V184 » Fri Oct 30, 2020 10:54 pm
Derv wrote:Nice looking custom mate, what parts did you all need to facelift it? wouldn't mind doing that to my own van
Probably plenty of knocked off front ends on ebay etc :shock:
V184
Location: You're right, V184 is an arsehole with a chip on his shoulder........
Return to Transit Custom
