Suspension question
Re: Suspension question
Postby 2020FMX » Mon May 03, 2021 8:45 pm
conrod wrote:I watched the youtube video on installing the Biltein kit last year. If I recall correctly the installer cut the rear bump stops down after installing the rear springs. If this has not been done, the rear will sit on the bump stops at ride height, which will give a very stiff ride in the rear, as well as rubbish grip. Poke your head under the back, and have a look if the bump stops have a gap between them and the rear axle.
Ok, that’s useful info. Thank you very much. I will look.
2020FMX
Suspension question
Postby 2020FMX » Tue May 04, 2021 3:42 pm
I’ve taken a couple of photos of the stopper, trouble is I can’t get the van on the flat easily as it’s real hilly my way. Does that matter?
What do you guys think?
2020FMX
Postby Mike » Tue May 04, 2021 4:20 pm
Err, that looks like the bump stop is touching? Have you said which van you have, 290, 310?
Mike
Wind up merchant!
Postby 2020FMX » Tue May 04, 2021 4:28 pm
Mike wrote:Err, that looks like the bump stop is touching? Have you said which van you have, 290, 310?
It’s a DCIV 320 swb.
2020FMX
Postby Mike » Tue May 04, 2021 4:31 pm
2020FMX wrote:It’s a DCIV 320 swb.
That could be part of the problem, originally sports were 290 only, were your rear springs/dampers specifically for a 320?
Mike
Wind up merchant!
Postby 2020FMX » Tue May 04, 2021 4:37 pm
They were quoted as being for 2014-2021 transit custom sports. The seller has different ones for different years of production.
2020FMX
It was these on eBay Mike
https://www.ebay.co.uk/itm/193269708163
2020FMX
Postby Mike » Tue May 04, 2021 4:52 pm
That's the problem then, they're not the correct dampers (take note that the seller called them 'shockers', which they're not). Also I don't think that it should be sitting on the bump stops like it is, but someone with a Custom 320 would have to confirm or otherwise.
IMO you'd probably get away with the dampers being wrong if it wasn't on the bump stops.
Mike
Wind up merchant!
Postby 2020FMX » Tue May 04, 2021 5:00 pm
Mike wrote:That's the problem then, they're not the correct dampers (take note that the seller called them 'shockers', which they're not). Also I don't think that it should be sitting on the bump stops like it is, but someone with a Custom 320 would have to confirm or otherwise.
Can the bump stops be cut down to solve the issue?
2020FMX
Postby Mike » Tue May 04, 2021 5:05 pm
2020FMX wrote:Can the bump stops be cut down to solve the issue?
IIRC there were some shorter bump stops available. Have a search for Seikokid posts, he's lowered his sport and has posted plenty of useful info.
Mike
Wind up merchant!
Postby APW » Tue May 04, 2021 5:18 pm
As conrod said above, Bilstein have a video on FB showing the installation on a custom sport, the Technician cuts off the lower section of the stop at about 1:24.
https://www.facebook.com/BILSTEIN.uk/vi ... 822295226/
APW
Postby V184 » Tue May 04, 2021 5:36 pm
the spring dictates the height not the damper
V184
Postby Mike » Tue May 04, 2021 5:54 pm
V184 wrote:the spring dictates the height not the damper
Err, we know that. Got anything useful to add?
Mike
Wind up merchant!
Postby 2020FMX » Tue May 04, 2021 6:07 pm
I have had a word with my mechanic guy who agrees with cutting down or fitting shorter stops. (He’s a general mechanic not a suspension specialist, but I’d have thought he would have suggested it himself)!! Never mind, at least I’m getting closer to the desired set up. Thank you all for your input so far. I will update when all is done.
2020FMX
Postby Mike » Tue May 04, 2021 6:43 pm
That’s the cheapest and quickest option and should make it ride a bit nicer.
Mike
Wind up merchant!
Return to Transit Custom
