Speedo not working
Speedo not working
Postby Nathan-f » Thu Jan 27, 2022 7:18 pm
Hi all,
I’ve got a 2013 mk8 transit custom, when I bought it a few months back the Speedo didn’t work. It kind of flickers and judders then stops working all together. All other clocks and gauges on the dash work correct and no warning lights or error codes. (Before I messed with it).
I’ve taken the rear abs sensors out and cleaned them which seemed to improve the speedo slightly though using my gps app it still wasn’t accurate. Also a mechanic plugged a scanner in and activated the Rev and Speedo clocks, which both worked done the needle sweep.
I did happen to munch one of the front sensors up while removing it, so I now have the airbag, tcs and abs lights on the dash but once the new sensor arrives I assume they will go out as it was before.
Has anyone had a similar issue?
Nathan-f
Re: Speedo not working
Postby Altransit » Thu Jan 27, 2022 8:16 pm
Welcome to the forum :D
I've moved your post to the 'Custom' section, because it's not a Mk8 (which is a different van)
Good luck 8)
Return to Transit Custom
