Hi everyone , hope you are all good,
I have an issue with my 2014 125hp custom(166k) and quite honestly its breaking my soul, lol.
So , from the start, very very occasionally it would go into limp mode, i worked out this was happening when i would be gently cruising at motorway speeds and would get to a big hill, need to give a lot more gas to maintain speed ,,I went down the A34 twice n 6 months and it happened in exactly the same spot. big steep hill, limp mode . Switch it off and back on , limp mode gone, Nothing for months after.
i pulled code , p0089,,,this code is a recurring theme!
Being so random i decided to let it develop.
Next , in the past 6 months or so, ive noticed the engine sounding more and more "old transit".Bit more knocky, and growly, put that down to 166k.
then recently i genuinely thought it was knackered, on a cold start , got a real noticable metallic sound , possibly a knock.
It was nearly due a timing chain , so i did that,,, tensioner was absolutely toast , but made no difference to metallic knock type sound.
Decided to run it till it expires.
But then i noticed sometimes it would purr like a kitten from cold start , and be completely normal, other times it would rattle and knock like a b**ch.
The metallic knocking is only ever at tickover.
So my assumption is , that im having random fueling issues , that sometimes make it run very noisy .Xmas eve ,i started and knew straight away , it was in noisy mode, so as soon as i got to a fast road i booted it. Limp mode ,,,switched off , back on =fine.....P0089 "fuel pressure regulator typeA" pulled.
Actions i have taken so far...
New fuel filter
New egr
New cam chain kit, (i know this is irrelevant )
New PCV, this was a cheap one , but symptoms are exactly the same .
New throttle body.
reset all adaptions, and done static dpf regen.
When doing a pilot relearn ,,,, the knocking was truly awful on the decel. so much so i had to stop it cos i feared it would go bang.
Wait , theres more lol!!!
for some reason the TPS reading is stuck at 92.94%. I replaced the throttle body because of this , no difference , i also pulled the pedal assembly , and tested it , all seems fine,,,it has has voltage.
And maybe most importantly, fuel pressure at idle , is 2200kpa desired , but the actual pressure fluctuates between 1900to 2350 ish,,,, and i have yet to see the pcv cycle once????
Any help would be greatly appreciated.
sorry for the long post , hope some of you get this far lol, thanks in advance
