2019 Ford Transit high pitch ring/squeak
Postby theclassicladdie » Thu Aug 13, 2026 11:34 am
Hi all,
Wondering if the kind people of this forum can help me! :)
My Ford Transit Custom (2019, 60K mi) began making a high pitched squeak a few months ago.
This has since made two garage visits, with work done:
First garage visit:
- Took the wheel assembly apart and could not see any issues and test drove OK (I suspect they didn't drive it at speed for long).
Second garage visit:
- Nearside/offside disks, pads and bearings have been changed (bearings were not recommended, however I asked for these to be changed with mileage).
- Offside calliper was changed 5 months ago as it was overheating when braking (this resolved this).
- Nearside calliper has not been changed.
Some behaviours:
- More frequent on at 50mph+ driving for 20-30 minutes. Assume something is heating and expanding?
- Have driven 30 minutes before without issues, less common.
- When the wheel is straight, the noise can subside. When slightly right (can't full lock on the motorway lol), the noise increases. When the wheel is left, it can make a low pitch howl.
- Braking will totally remove the noise
- The noise is definitely generating from the front of the van, as it gets louder when cars pass me and echos of the car
- Wheels are new in January
- No smell or extreme temps from the wheel assembly
https://youtube.com/shorts/qRRMnrbDMb4? ... k4N0idQ_uW
https://youtube.com/shorts/X6xQMhIbVPA? ... 3-gkiebMYQ
Here is a couple of videos of the noise.
I've spent a fair bit of money in labour and parts to fix this and its still going on. My plan is to take it to a separate garage, but does anyone have anything I can ask the garage to look at specifically based on that? I just don't want to be throwing parts at things that don't need replaced.
Thanks! :)
John
theclassicladdie
Re: 2019 Ford Transit high pitch ring/squeak
Postby metalworker0 » Thu Aug 13, 2026 7:07 pm
Have a look at the steering pump pulley .. these have been known to come loose or brake off .. there maybe a phase before that, were it starts making noise .. i don't know.
some had plastic ones, some had metal .. some three bolts , some with peened over centre fixing over plastic .. its the peened over one that fails
Postby Herbert Hound » Sat Aug 15, 2026 11:46 am
Is it very responsive to any accelerator pedal movement?
Does it make that noise on the over-run?
If the answers are "yes" then "no" then it sounds like your turbo. My van started sounding like that that a month or so ago. I've a 2019 Transit Custom with 71,000 miles ... it's just had the wetbelt done and the mechanic said, as soon as he heard my van, that's a broken turbo mounting bracket (it was) and your turbo will need replacing soon. He does a lot of Transits... a local window & door replacement company run a fleet of ~20 Transits and he does all their work for them.
Herbert Hound
Postby theclassicladdie » Wed Aug 19, 2026 3:19 pm
Hi both,
Thanks for replying.
I have checked both items:
- Steering pump pulley doesn't show any signs of damage
- Doesn't increase with accelerator or over-run, but interestingly when having a wee look under the bonnet I've discovered this black soot, is this relating to the turbo as you mentioned?
theclassicladdie
Postby metalworker0 » Wed Aug 19, 2026 5:03 pm
i'm not familiar with looking at the 2 litre ecoblue engine ..from your picture, im not even sure which way im looking and what direction .. and what at .
i just looked at loads of used ecoblue engines on ebay .. and i cannot find a view from the same perspective showing the same items
Postby theclassicladdie » Tue Aug 25, 2026 10:01 am
No worries but thankyou for your help regardless.
Had another look myself, can't really see anything. Will take it to a different garage for another opinion and will report back if I get any good news..
theclassicladdie
Postby theclassicladdie » Sat Aug 29, 2026 10:50 pm
Hi,
Actually having a look again, not sure if the rear of the discs are supposed to look like this? If anyone has any ideas?
theclassicladdie
Postby metalworker0 » Sat Aug 29, 2026 11:12 pm
some scoring , perhaps small stone embedded in the pad
that would make a ringing noise
Return to Transit Custom
