Serpentibe belt routing
Postby Frogwell » Sun Sep 06, 2026 10:57 pm
Evening all,
After a fun filled Saturday last week which saw me having a a nine hour wait and two hour journey on the back of a recovery wagon after my crankshaft pulley decided to throw it's toys out the pram I thought it best if I invest it a new pulley that is hopefully glued together a bit better than the last one.
I got the old pulley off and the new one on without too much drama, but I'm struggling a bit with the route of the new serpentine belt. I took photos before I removed the old one, although since the pulley had come apart I'm not totally sure it can be trusted as the belt could well have popped off the original route. I looked in the Ford manual and it shows the belt going round a pulley between the crankshaft and alternator, but when I try this it's just slightly too tight to fit with the tensioner all the way down, I might just be able to get it to fit if I use the belt fitting tool, but haven't tried yet.
If I bypass the pulley between the crankshaft and the alternator (as shown in the Haynes manual) and the picture of my engine below then the belt fits fine and still has plenty of tension on it, and this was actually the way I think it may have been fitted before, although the pulley does look like it has been used as it's dirty and scuffed.
I also found a picture on the interweb showing it going round the extra pulley (the other picture below).
Not quite sure what to do. I could bypass the extra pulley, it fits fine but is is going to be too loose once the belt has warmed up and for a new miles under it. Then I could try and force it round the extra pulley but is that going to put too much strain on the belt and pulleys.
Any suggestions folks?
Cheers, Mark
Frogwell
Re: Serpentibe belt routing
Postby metalworker0 » Sun Sep 06, 2026 11:21 pm
is this a better picture
https://i.ebayimg.com/images/g/TMIAAeSw ... l1600.webp
you have the wrong belt or the crankshaft pulley is different if it will not fit
Postby andz327 » Sun Sep 06, 2026 11:44 pm
looking at your picture it'll be the Ford manual that's same as yours which is same as metal man showed you but you've got the belt for the Haynes manual one and looks shorter , no visible numbers on the old belt??
andz327
Postby Frogwell » Mon Sep 07, 2026 11:50 am
Thanks for the replies Gents. I did wonder if the belt was incorrect. It is the same length as the old one, although that's not to say the old one was correct of course. That said, a bit of googling seems to suggest this is the longest belt available. I was wondering if I just wasn't pushing the tensioner down far enough as and a bit more googling later, sure enough there is an offset tensioner tool recommended for the 2.2 engine. My breaker bar hit the wishbone and driveshaft before it can go far enough.
I think this is probably going to require the grinder, welder and a rummage through the box of metal off cuts.
Frogwell
Postby andz327 » Mon Sep 14, 2026 9:29 pm
it's £10 for the tool
andz327
Postby BHM » Wed Oct 07, 2026 9:41 pm
andz327 wrote:it's £10 for the tool
Hi, got a linky to tool?
BHM
BHM
Postby andz327 » Thu Oct 08, 2026 12:21 am
BHM
https://ebay.io/m/P0zyt8
andz327
Postby BHM » Sat Oct 10, 2026 10:53 am
Ordered, thx.
What milage would one expect from the crank pully?
BHM
BHM
Postby Radiofence » Thu Oct 15, 2026 10:58 pm
I have 352kmiles on mine.
I bought a proper tool too, but I lost it straight away so its always the screwdriver for me!
Transit custom 2.2
Radiofence
Postby BHM » Mon Oct 19, 2026 3:02 pm
Ok Thx, I have 135K. I shall check the pully for secrurity when I change the belt, same goes for the idler pullies.
BHM
BHM
Return to Transit Custom
