Which fan?
you have one inside the dash and one in front of the radiator
if radiator fan .. main cause .. the AC pressure switch ,, or the fan relay
You have a relay that is air conditioning clutch relay .. I can see one called
F38 .. the picture in the manual shows a
fuse for that
but names it as a relay in the list .. you work that out, i cant ... i don't know if this fan clutch relay also switches on the radiator fan??
Also the radiator fan / fans have relays
Anyway look at this see if you can make some sense of it
IF YOU FIND A RELAY ,you are going to be swapping a relay with another out of the same fuse box to diagnose it
The owners manuals
https://www.ford.co.uk/support/vehicle/ ... er-manuals The one i picked, i could be wrong.. it goes on the
build date, there are 4 to choose from
https://www.fordservicecontent.com/Ford ... ldtype=web
Put your vin number in here to get the correct one .https://www.ford.co.uk/support/owner-manuals Some models have two cooling fans at the radiator, others have one fan that has 2 speeds.. so important to pick the right owners manual .
