Upgrading the door speakers
Re: Upgrading the door speakers
Postby arf33 » Fri Jan 29, 2016 1:34 pm
ok, now I can confirm that no more rpm noise through the speakers after I moved the crossover from the electrical wiring...
stupid problem...easy fix... good to remind :P
arf33
Postby Mike » Fri Jan 29, 2016 3:46 pm
arf33 wrote:ok, now I can confirm that no more rpm noise through the speakers after I moved the crossover from the electrical wiring...
Good news :D
Mike
Wind up merchant!
Postby Camper steve » Fri Jan 29, 2016 8:42 pm
Hi All
ok i admit it, i know nothing these new fangled wireless music do-dads.
but i can tell my up front door speakers are pants. and that my big band 78's dont fit in the CD slot. :P
can any of you experts tell me if i buy these will they fit as a straight swap and at 30 quid will they make it sound much better when i crank
vera lyn all the way up to 11?
http://www.ebay.co.uk/itm/331676388124? ... EBIDX%3AIT
my eternal gratitude :D
Camper steve
Postby Alar » Sat Jan 30, 2016 8:39 am
I doubt that you will make the difference between new and old without dampening the doors and amp...
125ps 310LWB Trend Powerty Edition
Alar
Postby seikokid » Tue Feb 02, 2016 8:29 pm
Very helpfull posts here and have just installed a nice set of focals today's myself - however they came with crossovers and I would like to ask if there is a good place for them . Saw that the door wires are on a plug and so running a cable to the door and putting them in there isn't an option
Does the tweeter run straight from the head unit as such the door speaker or are they in series ?
at the moment I'm using them without but would be nice to install them without having to rewire everything
seikokid
Postby AllAboardTheWolfBus » Wed Feb 03, 2016 12:36 am
I'm not an expert by any means but I believe coaxial speakers are designed for when you don't have separate tweeters (they have them built in). As such, you'd get two lots of highs, and I'm pretty sure this isn't ideal.
AllAboardTheWolfBus
Postby moley551 » Wed Feb 03, 2016 12:41 am
Owning a ford you need all the "Highs" you can get :D :D :lol:
"Don't find fault, find a remedy"
H. Ford
moley551
Postby thedugmaster » Wed Feb 03, 2016 11:20 am
I recently added sound deadening to the inside of my doors and the backs of the door casings and the improvement is significant. Interestingly, the rear speakers in the Tourneo seem to perform much better than the fronts. I'm not sure if they're the same speakers or whether the mounting of them is better acoustically.
I will eventually upgrade, but am not sure yet what the best options are, be it speakers, amp and sub, head unit or all of the above.
thedugmaster
Postby Camper steve » Wed Feb 03, 2016 1:48 pm
thedugmaster wrote:I recently added sound deadening to the inside of my doors and the backs of the door casings and the improvement is significant. Interestingly, the rear speakers in the Tourneo seem to perform much better than the fronts. I'm not sure if they're the same speakers or whether the mounting of them is better acoustically.
this is what i was after cheers, a cheap way to improve the standard setup, im off to the hardware shop to see if i can get the same as that posted earlier (with pictures) :D
Camper steve
Postby arf33 » Wed Feb 03, 2016 2:01 pm
seikokid wrote:Very helpfull posts here and have just installed a nice set of focals today's myself - however they came with crossovers and I would like to ask if there is a good place for them . Saw that the door wires are on a plug and so running a cable to the door and putting them in there isn't an option
Hi,
I can suggest to don't fix the crossovers ore speakers cables to the existing OEM wiring of the van, if you read my last posts I fix a noise problem by moving one crossover .
bye
arf33
Postby thedugmaster » Wed Feb 03, 2016 3:13 pm
Make sure you get the stuff that doesn't go brittle, stink and/or fall off in the summer sun.
8)
thedugmaster
Postby seikokid » Wed Feb 03, 2016 11:36 pm
Hi,
bye
Can you explain more please ?
The speaker cable from the cab into the door is through a connection plug , there is no other way to run cables into the door without alot of work
Did you run separate cables to all speakers ?
I do get engine noise but it is since I added a tuning box , it was there before I put the new speakers in and has now become louder with the new speakers but this is not a problem for me
seikokid
Postby seikokid » Wed Feb 03, 2016 11:47 pm
Just found a copy of the wiring colour code , it mentions only that there are 2 front speaker and 2 rear speaker wires. I really would like to find the cable points were the tweeters and doors speakers join
seikokid
Postby Mike » Thu Feb 04, 2016 9:19 am
seikokid wrote:Just found a copy of the wiring colour code , it mentions only that there are 2 front speaker and 2 rear speaker wires. I really would like to find the cable points were the tweeters and doors speakers join
Probably close to the A pillar, it doesn't matter though as the signal is exactly the same. It might be a good place to mount the x-over though.
Mike
Wind up merchant!
Postby seikokid » Fri Feb 05, 2016 11:34 pm
I have looked into this - being an electrician myself I can see how it's not an easy job to fit these crossovers , in that this is a 1 year old vehicle and to start cutting up the loom is not what I really wish to do and there's quite a tight bunch under that dash . I'm not that fussed about the "perfect sound " because already fitting these speakers is far better than what I had and that was ok for me , just my hands free had started to wear out the tweeters . So I had a chat with my electronics repair guy and also some helpfull guys down at one of londons big car audio centres , if I fit a 4.7uf or similar Cap Across the new tweeters I will be back to my original set up just with new speakers . Until I can find a loom splitting kit or something neat and professional I'll use this method for now
seikokid
Return to Transit Custom
