Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit today
Postby TallPaul » Thu Jan 22, 2015 8:18 pm
deno 1 wrote:well........nowt doing today so fitted the kit.
WOW big difference.......no black spots.....no error messages.
Big thanks to mike for the info..i one happy man..
Dunno why but my heated screen decided to work on both sides after i fitted the lights........hahahahahahaha
Does anyone have a link to the thread about the dodgy earth on the screen as im thinking thats all thats wrong with mine...
Here it is in HEAT WINDSCREEN although I've had 2 more screens after that!
TallPaul
Postby Lotte » Fri Jan 23, 2015 7:48 pm
Sorry if already asked by someone else,if you change the lights for the HID kit,do the cornering lights still work then??
Sorry if this sound like a stupid question.
2015 Deep impact blue sport
Lotte
Postby Tran59 » Sat Jan 24, 2015 9:00 am
Lotte wrote:Sorry if already asked by someone else,if you change the lights for the HID kit,do the cornering lights still work then??
Yes, everything still works 100% The cornering lights are completely separate to the projector lenses you put the HID bulb in.
The best mods are the ones you don't see
Tran59
Postby Lotte » Sat Jan 24, 2015 6:33 pm
Anybody knows if this kit is available in Belgium??
Price of the kit??
Lotte
Postby Mike » Sat Jan 24, 2015 7:15 pm
Lotte wrote:Anybody knows if this kit is available in Belgium??
Price of the kit??
Yes, they ship to europe.
Mike
Wind up merchant!
Postby Lotte » Sat Jan 24, 2015 8:03 pm
ok,where do i buy the kit??
Lotte
Postby Mike » Sat Jan 24, 2015 11:25 pm
Lotte wrote:ok,where do i buy the kit??
Read the thread ;) viewtopic.php?f=65&t=142882&start=15#p1195184
Mike
Wind up merchant!
Postby iverem » Sun Jan 25, 2015 8:38 pm
After trying some sets from ebay (which didn't work, or needed resitor/relay, or gave "dimlight error")
I finally found these which work clean with only the ballast and hid lights, (55 watt/4300K)
If I use the van every day the dim light can be set on "automatic". (accu is at good voltage)
turning light left is on and the mist lights , color HID is 4300k is bright white
iverem
Postby keeff » Sun Jan 25, 2015 9:51 pm
I have done a few hundred miles since fitting the kit and the ballast have stayed in place. I drilled a hole then used a self tapper with spring washer to hold them in place and the other end rests on the top of the light unit. The one fixing works ok and it can all be fitted to the light off the van then reconnect the light wiring plug and refit light.
As you can see from the photos they stay clean and dry.
Hope this will help others .
keeff
Postby Tran59 » Sun Jan 25, 2015 10:13 pm
^ nice idea
Tran59
Postby sezyal » Mon Jan 26, 2015 4:52 pm
For cornering, these worked for me if you have 5000K Xenons.
http://www.ebay.com/itm/2-x-H1-55W-Ligh ... 463231f6c0
Didn't break so far, cheap anyways buy some spares. It takes a month to reach you from China, in case you are first timer on Ebay.
2014 Tourneo Custom 155 SWB Titanium Plus
Stratosphere Blue
+18" Sport Wheels
+HID Kit
sezyal
Postby Scottleroy » Thu Feb 05, 2015 3:51 pm
Hello every one
Just reviewed my 64 plate custom limited and Im wondering if you can change the OlD fashioned orange colour DRL to a nice modern cool white
Any help is much appreciated
Scottleroy
Postby Sparkeselectrical » Sat Feb 07, 2015 5:51 pm
Scottleroy wrote:Hello every one
I fitted xenon bulbs in mine and they give a white light
New 170 Limited 290 L1 DCiV
Sparkeselectrical
Postby John Johnson » Sun Feb 08, 2015 9:40 am
So has anyone fitted a hid kit that does not throw canbus errors up apart from the hid4us one ?
John Johnson
Postby Sparkeselectrical » Sun Feb 08, 2015 11:36 am
John Johnson wrote:So has anyone fitted a hid kit that does not throw canbus errors up apart from the hid4us one ?
Judging by all the other posts and comments about these, I doubt it very much!
Sparkeselectrical
Return to Transit Custom
