Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit today
Postby John Johnson » Sun Mar 09, 2014 7:03 pm
For the record to help other which bulb kit did you go for and for the sidelights ?
Bulb type and size will help some unsure
John Johnson
Postby Mike » Mon Mar 10, 2014 9:31 am
John Johnson wrote:For the record to help other which bulb kit did you go for and for the sidelights ?
Mike wrote:Fitted the hid conversion, tbh it was dead simple, took less than an hour so not many pics.
This is the kit, http://www.hids4u.co.uk/h7-35w-ultimate ... n-kit.html 5000k projector H7 I used the discount code STRATHY to get £17 off.
Before
Changed bulbs for hids, added a little shrink wrap over the terminals to be safe.
Cut the bulb cover to fit the grommet
Difference
And finished
I'll pop to the mot place when I get a chance but the cut off is very good, the beam very even and no protests from other drivers......yet.
Dip beam
Main beam
The sidelight bulbs are these http://www.powerbulbs.com/product/w5w-l ... white-twin
Mike
Wind up merchant!
Postby John Johnson » Mon Mar 10, 2014 2:57 pm
Good lad ... I shall get you a Scooby snack for that
John Johnson
Postby Goliath » Mon Mar 10, 2014 3:08 pm
This is the kit, <a href="http://www.hids4u.co.uk/h7-35w-ultimate-xenon-hid-conversion-kit.html" class="skimwords-unlinked" target="_blank" data-skimwords-id="0" data-skimwords-word="http%3A%2F%2Fwww.hids4u.co.uk%2Fh7-35w-ultimate-xenon-hid-conversion-kit.html" data-group-id="0" data-skim-creative="300002" data-skim-product="0" title="" style="">http://www.hids4u.co.uk/h7-35w-ultimate-xenon-hid-conversion-kit.html</a> 5000k projector H7 I used the discount code STRATHY to get £17 off.
Before
The sidelight bulbs are these <a href="http://www.powerbulbs.com/product/w5w-led-driving-6000k-cool-white-twin" class="skimwords-unlinked" target="_blank" data-skimwords-id="0" data-skimwords-word="http%3A%2F%2Fwww.powerbulbs.com%2Fproduct%2Fw5w-led-driving-6000k-cool-white-twin" data-group-id="0" data-skim-creative="300002" data-skim-product="0" title="" style="">http://www.powerbulbs.com/product/w5w-led-driving-6000k-cool-white-twin</a>
Did you buy the Philips CANbus warning canceller to go with the sidebulbs? or does it work without the canceller?
Goliath
Postby Mike » Mon Mar 10, 2014 3:41 pm
You only need a can bus canceller for the brake lights and indicators, the HID kit has it built in.
Mike
Wind up merchant!
Postby limitedblack » Mon Mar 10, 2014 4:52 pm
How do you select dipped and main on these, are the oe projectors just single filament with a moving shade?
Happy Easter
limitedblack
Postby Mike » Mon Mar 10, 2014 5:06 pm
limitedblack wrote:How do you select dipped and main on these, are the oe projectors just single filament with a moving shade?
Twin lights ;)
Mike
Wind up merchant!
Postby Goliath » Mon Mar 10, 2014 5:30 pm
Twin lights ;)
so you have 2 kits? one for main and one for dipped?
Goliath
Postby Mike » Mon Mar 10, 2014 5:33 pm
Goliath wrote:so you have 2 kits? one for main and one for dipped?
No, just on the dip beam. You can't fit HID's to the main beams.
Mike
Wind up merchant!
Postby Tran59 » Tue Mar 11, 2014 1:41 pm
Mike wrote:You can't fit HID's to the main beams.
Yep, xenons don't heat up fast enough to be used as flashers. Can't wait for LED headlights to become the norm.
The best mods are the ones you don't see
Tran59
Postby limitedblack » Tue Mar 11, 2014 8:27 pm
Getting close, but £300 per light is even too much for me.
Happy Easter
limitedblack
Postby TallPaul » Tue Mar 11, 2014 10:01 pm
Surely HID's are fine for main beam, I've had them in a couple of cars in the past? They may take a while to warm up but the initial striking of the arc is much brighter than a normal bulb so they'll flash alright, its just repeated cycling them on and off blows the "bulbs" (burners?) pretty quickly.
TallPaul
Postby Mike » Tue Mar 11, 2014 10:40 pm
If you say so, but it doesn't change the fact that you can't fit HID's to the main beam in the Custom.
Mike
Wind up merchant!
Postby Goliath » Tue Mar 25, 2014 4:34 pm
here is my HIDs from hid4u
now i just need to lower it and put on my new rims :)
Goliath
Postby Tran59 » Tue Mar 25, 2014 5:06 pm
Looking good, and - as I discovered on a particularly dark country road a few days ago - they give a fantastic improvement in visibility compared to the standard bulbs.
How did you black out your headlights?
Tran59
Return to Transit Custom
