2016 transit custom 2.0 overheating
Re: 2016 transit custom 2.0 overheating
Postby canny_83 » Fri Dec 03, 2021 12:48 pm
Icemans10! wrote:Hi everyone,
Been having trouble with my 66 plate euro 6 2.0 lite custom randomly over heating, it generally does it when travelling at around 60 - 70 mph when under load, I've just changed the water pump & I believe looking at paperwork that came with the van the thermostat has been replaced also, Whats strange is the blowers start blowing cold just before it overheats ... any ideas anyone ? Its been suggested it could be the egr valve cooler but don't want to keep throwing money at it Unless I know for definite.. someone pleeeeze pleeeze help
Did you get the issue resolved? We’re in the same boat doing the same thing
canny_83
Postby Rameire32 » Fri Jan 14, 2022 9:15 pm
Good evening,I’m having similar problems with my 2016 transit custom 2.0 add blue,250,000klms on it,6 months ago I had the timing belt replaced,recently got a problem with the water blowing from the reservoir bottle,replaced the thermostat,still blowing when vans uphill mainly any advice would be great thanks
Rameire32
Postby Scarface-uk » Fri Jan 28, 2022 11:29 am
Rameire32 wrote:Good evening,I’m having similar problems with my 2016 transit custom 2.0 add blue,250,000klms on it,6 months ago I had the timing belt replaced,recently got a problem with the water blowing from the reservoir bottle,replaced the thermostat,still blowing when vans uphill mainly any advice would be great thanks
Scarface-uk
Postby gedas » Mon Mar 28, 2022 8:35 pm
hi, did you get it fixed? what was the problem?
gedas
Postby Johnm28 » Wed Apr 19, 2023 1:39 am
Hi iceman10 did you ever find out what was wrong with your van as I have a 2019 transit doing the same thing your van has been doing if you can let me know would be great
Johnm28
Postby bjpro » Sun Aug 06, 2023 8:47 pm
Did you get this solved?????
Im stuck in Hungary, with the same problem.
Never had this before, im pulling a caravan, but during the year it is also always pulling. "Whats strange is the blowers start blowing cold just before it overheats ... " just the same.
Im going up hill 2000rpm, (I believe it is always running a bit hot, so just a bit warmer than usuallly), during a low torque climb it suddenly says overheating and goes in limp mode. I let it run for a few secs stationairy, fault goes away. if I ref it to 3500 rpm and turn the heating on (till trere is hot air coming out) the problem is solved, till the next time (can be 10km or 150km), turn it on and of also works. If I start driving direct after it directly overheats again, ( fault is back)
I ran it for 100km had no fault checked the water level "OK" ; 10km later fault is there, pushes out the water.
Went to Ford they said thermostaat, 2nd generation not solved
bjpro
Postby Leetgriffiths » Wed Dec 20, 2023 12:07 am
Any resolutions to these? Have the same problem and nothing seems to sort it. Overheats on the bypass/motor way as soon as i start going up a hill, pull off the sliproad, slow down and it goes back to normall. Had the thermostat changed along with all the belts.
Transit MK7
LTG Joinery and Building
http://www.LTG-JB.co.uk
Leetgriffiths
Return to Transit Custom
