t0m541 wrote:Great "how to"
My van has the CD/MP3 head unit, do you think this could be swapped out for the later touchscreen unit you have fitted.
Looking at the touchscreen units on eBay, they dont seem like they would be the same physical size as the CD player thats there now.
t0m541 wrote:Had a tinker around today, pulled the dash front off and extracted the CD player.
The connections on the back of it are nothing like the ones for the later head unit.
Also the newer unit is physically deeper than the CD player and won't fit in the aperture, it sticks proud by around 20mm.
So that's not getting fitted either.
I'll be putting it up for sale, I'm sure someone with a 2018 on van will be needing one.
liongreen wrote:Hi
Just bought all that parts with an extra FORD / Transit Custom USB-C PORT / NK4T-14F014-AA
Head unit - LK2T-18D804-HH
Screen - L1BT-18B955-FB
Fiesta Loom - H1BT-14B079-SC
USB Media Hub - HS7T-14F014-AC
Just checking if that will work or need to get anything else to make it work, just spend like £463.00 in parts and really want make it work.
liongreen wrote:Mafty
After installing the head unit and screen I’m facing a problem with usb ports, literally stuck where to place the adapter and where to connect or soldering cables where to where. Everything working apart from usb where cuts almost instantly after few seconds and trying to connect again and cuts again.
Regards
liongreen wrote:Mafty the top one I’m trying to put type C instead of normal USB and the type C got 2 mini usb and need extra power. Do you think using same route that you explained will work or just work using normal usb?
Regards
