Alfaroo wrote:Hi , just done a timing belt change today on 2016 transit and the same thing happened, rotated engine several times to align marks & ping both thin gears on idler and pump popped off the back and are now loose. What was your fix for this. I removed the idler pulley and couldn’t work out how to position it and I’m now waiting for a tool to arrive to remove the pump gear
I didn’t remove the fuel pump gear.
I made I little tool to hold the fuel pump gear from a bit of broken hacksaw blade. One end had a hole for a bolt that screwed into the fuel pump gear wheel the other end had a hole that bolted into one of the timing cover holes. That held the fuel pump gear static. The crank was held by the tool from the timing belt tool kit. Then I could remove the intermediate gear without everything going out of time. I managed to get the sprung wheel back onto the fuel pump gear from the front with the help of a little dentist mirror , twist it back into the tensioned position and insert the pin (or drill bit) into the front hole. I put the sprung wheel onto the back of the intermediate gear, twisted it into the tensioned position and inserted the pin into the front hole to hold it. I then refitted the intermediate gear with a new bolt (very important) then you can pull the pins and you should be back in business. I did have tippex dots all over the place just in case something moved. I made a plastic spacer the same thickness as the flywheel pulley from sink waste pipe so next time I turned the engine over the crank gear can’t ride forward and release the sprung gears.
Hope this makes sense.
Sorry it’s taken so long to reply. I’ve been on holiday.
