Hi every one did cold compression test today
Number 1 cyl 200psi
Number 2 cyl 200psi
Number 3 cyl 180 psi
Number 4 cyl 220psi
Any idea what they should be thinking they are all low
What results were you guys getting? Thanks
Gusxl250 wrote:Hi all quick update removed cylinder head all exhaust valves leaking
Inlets fine
Seats recut two new exhaust valves all reground
Starts perfect now
Muddyfunster wrote:Colr6 wrote:Just taken mine apart for exactly the same reasons 2021@ 35k replaced 8 exhaust valves due to blow by and corrosion. Seats recut. The piston tops on mine were even corroded so they’ve been changed as well.
Blimey that's a lot of work required. Are you doing it yourself or having to pay someone?
Colr6 wrote:Muddyfunster wrote:Colr6 wrote:Just taken mine apart for exactly the same reasons 2021@ 35k replaced 8 exhaust valves due to blow by and corrosion. Seats recut. The piston tops on mine were even corroded so they’ve been changed as well.
Doing it myself luckily I& you want to call it that ! When I took 5h3 head in for the seats re cut the guy informed me he had another 14 to do with exactly the same problem. So to me that is an inherent design fault somewhere
