Air con pressure switches
Re: Air con pressure switches
Postby metalworker0 » Mon May 12, 2025 8:39 pm
youll have to do more research on this
there seems to be a radiator fan control module ..on the 2.2 mk7s, so presume on the customs too ..although i cant find a listing for it
https://www.ebay.co.uk/itm/184054618081
Postby Altransit » Mon May 12, 2025 11:50 pm
As I recall, the two feeds are for the engine fan and the A/C fan, I seem to remember disconnecting both and putting 12v to both feeds, and then direct to the fan, bypassing the controller. In the case of my van, both the controller and the fan were working fine, in the case of the Focus, the fan controller turned out to be a dud. All diagnosed with a simple 12v feed.
Postby longhair » Tue May 13, 2025 3:34 pm
Cheers for that. I'll have a better look at it and see if I can work it out.
longhair
Postby longhair » Wed May 21, 2025 5:40 am
I have checked everything I thought it might be, found nothing wrong. I'm going to get a mobile air con guy in who has good reviews to have a look at it.
longhair
Postby longhair » Mon May 26, 2025 8:10 am
Well after all that, it was bad connection on the compressor. Thanks for the advice anyway.
longhair
Postby Altransit » Mon May 26, 2025 8:50 am
At least you're sorted 8)
Return to Transit Custom
