Automatic climate control set
Re: Automatic climate control set
Postby mavericktc » Thu Jan 07, 2016 5:28 am
Mike wrote:
mavericktc wrote:That sounds like a mk7 on the motorway which probably have the same heater control as the custom have in standard trim.
I woudn't blame me ACC unit for that.
Standard Custom heating is very good, I hardly ever touch the temp control once it's warmed up. As you say the MK7 was shocking at keeping the temp stable.
Interesting.
It's good on the other hand though. The custom will perform like my mk7 in the heating department. No surprises here :lol:
Hopefully it will work better because mine is fitted from factory (including aux heater with twin batteries). No hopes though....
mavericktc
Postby Alar » Thu Jan 07, 2016 7:38 am
Well, like a said, mine aux heather, or the park heather function has given up. It wont start on timer. Have twin batterys, connected one of those smart chargers to both batteries and it said that both are about 75% charged. Booked a time at dealers but its 3 weeks away and tonight had -19C outside :)
125ps 310LWB Trend Powerty Edition
Alar
Postby justin147 » Tue Jul 05, 2016 11:09 am
carlos_fu wrote:Anyone fitted this new set from FORD to add automatic hvac company reviews Portland control for our Customs? Looks good for 340 EUR
It is so costly.
justin147
Postby transcendent » Wed Jul 20, 2016 7:40 pm
i was thinking about getting this for my euro6 transit but ford told me the wring loom is different.
New to Transit the world
transcendent
Postby mavericktc » Wed Jul 20, 2016 7:48 pm
transcendent wrote:i was thinking about getting this for my euro6 transit but ford told me the wring loom is different.
You will have the answer within three weeks.
I'm having one in my euro6 which is ready to pickup around that time.
mavericktc
Postby Mike » Wed Jul 20, 2016 8:07 pm
Have they sorted the random temp glitch?
Mike
Wind up merchant!
Postby Sparkeselectrical » Wed Jul 20, 2016 8:10 pm
Mike wrote:Have they sorted the random temp glitch?
Didn't someone post earlier that it was fixed with a replacement unit??? :?: :?: :?:
New 170 Limited 290 L1 DCiV
Sparkeselectrical
Postby mavericktc » Sun Sep 04, 2016 11:10 pm
So apparantely you can't add the ACC to the euro6?
http://www.ford-accessories.co.uk/trans ... -products#
f*** this sh*t, I'm so tired of not getting what I'm ordering and paying for.
Why does it seem like I'm the only one in Sweden that knows ANYTHING about transits? :roll:
mavericktc
Postby oppre1945 » Sat Sep 10, 2016 9:46 am
What Is The Difference Between Air Con And Climate Control?
oppre1945
Postby S60r » Sun Sep 11, 2016 6:45 am
Air con is manual. Climate control is automatic, ie you set your desired cabin temp and the climate makes the necessary adjustments to achieve and maintain your chosen temp.
So... Are these any good? I've had a read through and still undecided!
S60r
Postby John_C84 » Mon Sep 12, 2016 11:31 pm
Can you get these in the uk.
John_C84
Postby mavericktc » Tue Sep 13, 2016 1:36 am
John_C84 wrote:Can you get these in the uk.
No, my co.uk link four post above is just an illusion. :|
mavericktc
Postby seikokid » Tue Sep 13, 2016 8:57 am
yes you can , but they have to be posted out from the larger Ford retailers
seikokid
Postby seikokid » Tue Sep 13, 2016 9:02 am
It's 50/50 to whether they are good , in still experimenting with mine. Initially on auto you will get the heat but after a while it assumes the ambient temp is higher than it is and thus blows cooler air out
Just having it on manual is worse in that it needs to be cranked up to give you heat
I like a steady flow of air . like having the fan on 1 and temp just under half
Too much hot and I feel uneasy. So for me it's fine and when I'm cold I turn it up on auto and have some vents closed
It's nice that in the cold mornings it auto adjusts the fan speed and heat to get the cab just right and also in the heat you can hit the auto A/C and get blasted by cool air and then it turns the fans down
Take from it what you will , I was forever adjusting the manual dials, I prefer the auto. Albeit it isn't Mercedes quality
seikokid
Postby Treespotter » Tue Sep 13, 2016 8:17 pm
Wolter
Treespotter
Return to Transit Custom
