What did you do to your Custom today?
Re: What did you do to your Custom today?
Postby ned » Mon Jun 10, 2019 6:52 pm
Dodge20 wrote:Made a start repairing a load of stone chips all over the front of the van. I can't believe how thin the paint is :shock:, it's almost like Ford have mastered paint application on the atomic level.
That's the downside of water based paint :?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Dodge20 » Mon Jun 10, 2019 8:17 pm
Tell me about it, at least they seem to be able to make it stick to the body work now. I had a '96 Chrysler Neon with the first generation of water based paints on, it started peeling off in sheets when it got to 4 /5 years old
Some people are like slinkies.... not good for much but bring a smile to your face when you push them downstairs.
2009 280 85hp
2015 290 Custom DCIV twin side doors 155hp(tragically killed)
Dodge20
Location: Go to the end of the world and turn left. (South Cumbria)
Postby Dodge20 » Wed Jun 19, 2019 9:19 pm
Washed it and gave it a full machine polish.
2009 280 85hp
Dodge20
Postby loot » Wed Jun 19, 2019 11:01 pm
Changed its name form red to pinky and f**** perky :cry:
Ids map here
loot
Postby Dodge20 » Sat Jun 29, 2019 3:41 pm
Attempted to change my fuel filter. The housing wouldn't turn and was starting to squash in on the sides. As I don't have a spare housing I gave up. Seriously thought I was going to crack it.
2009 280 85hp
Dodge20
Postby Dodge20 » Thu Jul 04, 2019 1:18 pm
Managed to get the fuel filter changed.
Not before time by the looks of it.
Contents of the bowl.
2009 280 85hp
Dodge20
Postby ned » Thu Jul 04, 2019 6:45 pm
Dodge20 wrote:Managed to get the fuel filter changed.
That looks mingin, bet it's still the original filter
ned
Postby Dodge20 » Thu Jul 04, 2019 8:19 pm
That was my first thought, wouldn't surprise me in the slightest.
2009 280 85hp
Dodge20
Postby littlejj » Sat Jul 06, 2019 9:26 pm
Picked up my new to me Custom.
littlejj
Postby loot » Fri Jul 19, 2019 12:26 pm
That's a record :P
Always been the same, might swap them around :P
Ids map here
loot
Postby Baron von Teuchter » Fri Jul 19, 2019 1:43 pm
Ordered it!
Brand new L2H1 DCIV in Black. Thinking about some of these:
Cheers
BvT
'19 320 Custom 130 L2H1 DCIV
'79 Group 4 RS2000
Baron von Teuchter
Postby Bigkenxx » Sat Jul 20, 2019 5:38 pm
Fitted new front discs and pads , new battery tomorrow
Bigkenxx
Postby BHM » Sat Jul 20, 2019 9:50 pm
Cut off weeping CV gaiter only to then discover the "supadoopa" slip-on replacement is the wrong size....
That me fckd till at leased Monday :evil:
BHM
BHM
Postby Dodge20 » Sun Jul 21, 2019 3:45 pm
Fitted new brake pads front and rear. As I was dismantling the off side front I noticed that the brake ware sensor had been put in back to front :?.
2009 280 85hp
Dodge20
Postby Baron von Teuchter » Mon Jul 22, 2019 3:27 pm
Kent Discos wrote:ImageImage
Sent from my SM-G955F using Tapatalk
They look amazing, 8x18”??
'79 Group 4 RS2000
Baron von Teuchter
Return to Transit Custom
