Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit DO NOT USE 55w KITS
Postby BringTheRain » Sun Feb 15, 2015 9:08 am
keeff wrote:Do you connect the harness to the battery?
That's a lot of work just to get the lights to work
Yeah you do. I guess you could connect to the jump port.
It's not a lot of hassle really. It is plug and play for around 80-90% of it.
BringTheRain
Postby BringTheRain » Thu Feb 19, 2015 8:46 am
Received the harness yesterday. It's a work of art!
I will post up some pics when i fit it all. Confident this will sort any issues!
BringTheRain
Postby keeff » Thu Feb 19, 2015 6:15 pm
That would be great if you post photos
Mine are off the van now. Drivers side had been playing up but on the way home the passenger side started to go on and off caused by a loss wire to the bulb. I will pop in and see them but it looks like the quality has gone down as a few on here are getting trouble
keeff
Postby BringTheRain » Thu Feb 19, 2015 8:00 pm
I don't think its the quality. I think the kits are drawing too much power and that causes issues over time.
BringTheRain
Postby Mike » Thu Feb 19, 2015 8:25 pm
BringTheRain wrote:I don't think its the quality. I think the kits are drawing too much power and that causes issues over time.
Well they draw their max current at startup, once they're lit they draw less current than a 55w halogen bulb. I wonder what the startup current draw is?
Mike
Wind up merchant!
Postby BringTheRain » Thu Feb 19, 2015 9:31 pm
It has to be higher than a halogen bulb as thats when i get the faults. Never ever when they are on, just when i switch em on!
BringTheRain
Postby Mike » Thu Feb 19, 2015 9:44 pm
Do you switch them on immediately that you've started the engine or once it's settled?
Mike
Wind up merchant!
Postby BringTheRain » Fri Feb 20, 2015 5:10 pm
Mike wrote:Do you switch them on immediately that you've started the engine or once it's settled?
within 5 secs of starting engine at a guess.
BringTheRain
Postby Mike » Fri Feb 20, 2015 5:26 pm
Try leaving it a little longer, I'm sure the surges are stronger while the charging system sorts itself out.
Mike
Wind up merchant!
Postby keeff » Fri Feb 20, 2015 5:47 pm
Mine would work ok with auto on as they would light before the engine started but played up when turning on with engine running.
keeff
Postby Mike » Fri Feb 20, 2015 6:22 pm
keeff wrote:Mine would work ok with auto on as they would light before the engine started but played up when turning on with engine running.
I wonder if that what's buggered things? If the lights come on before you start it, don't they then go off as you start the van and then come back on?
Mike
Wind up merchant!
Postby keeff » Fri Feb 20, 2015 8:04 pm
They work fine when starting but have two battery. It's when I am driving and turn them on or the auto function turns them on .
One side has always work ok all of the time until the wire came loss but that's is just a fault. So I am hoping they can help me as the lights are great but don't need them till next winter now as I don't use the van in the evening.
keeff
Postby Stusgsx » Wed Mar 11, 2015 9:07 am
I fitted the harness they sent me and guess what....it's bloody worse!!
Stusgsx
Re: Installed HID kit today
Postby Mike » Wed Mar 11, 2015 9:34 am
Stusgsx wrote:Had the same problem with the hids-direct kit.
Your problem seems to be with the van/install rather than the HIDS4U kit?
Mike
Wind up merchant!
Postby Stusgsx » Wed Mar 11, 2015 11:19 am
You can't exactly install it wrong. Without the harness they usually come on ok if I turn them on after I've pulled away. But if they don't both come on I have to stop and turn van off and on and try again. Gets pretty annoying
Stusgsx
Return to Transit Custom
