Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit DO NOT USE 55w KITS
Postby C8XY » Sun Jan 31, 2016 11:25 am
Gone out to work today, "dipped beam fault" on the display and one HID not working :(
Will contact HIDS4U in the morning, bit disappointed as was extremely careful during installation so can only be a faulty part.
C8XY
Postby keeff » Sun Jan 31, 2016 5:46 pm
That's what happened to me . Just be careful as mine cut the power in the ecu and had to go on the computer at the dealers to switch back on. Hopefully ford will add HIDS as a extra soon.
keeff
Postby arf33 » Sun Jan 31, 2016 11:18 pm
C8XY wrote:Gone out to work today, "dipped beam fault" on the display and one HID not working :(
uhmmm :shock:
I started to cross my finger too...
what a messy upgrade this HID one!
arf33
Postby C8XY » Mon Feb 01, 2016 1:31 am
keeff wrote:That's what happened to me . Just be careful as mine cut the power in the ecu and had to go on the computer at the dealers to switch back on. Hopefully ford will add HIDS as a extra soon.
Wow, couldn't drive the van I take it?
The faulty HID has been working fine since this morning. Just occasionally get the dipped beam fault. But hasn't stopped working since.
What worries me slightly is another message that came up, can't remember the exact wording of it but it was something to do with "waiting for engine"??? Or something relating to engine delay. Will keep an eye on it but ecu problems definitely not what I'm after!!
Edit: realised you said in the ecu, not to the ecu, either way sounds like a pain in the arse
C8XY
Postby Alar » Mon Feb 01, 2016 6:28 am
Engine start pending is the message you get when starting before the glowplug light is off
125ps 310LWB Trend Powerty Edition
Alar
Postby sparker000 » Mon Feb 01, 2016 8:41 am
I have seen the "waiting for engine" or some thing like that, when iI have tried to start it before the glow plug light has gone off. So if that could be what you have done probably this is unrelated.
sparker000
Postby poolie » Mon Feb 01, 2016 5:28 pm
C8XY wrote:
poolie wrote:Ordered code is Disco315
Let us know how you get on, the yellow cornering lights look terrible :(
Hi mate. Them bulbs don't fit it holder as the leds are to big, neither do they work, so I've sent them back today.
poolie
Postby Mike » Mon Feb 01, 2016 5:41 pm
When was your van built? There are (AFAIK) only two members here that have fitted the HIDS4U 35w Ultimate kit and had problems (all the other problems are from dodgy wiring, 55w kits and ebay kits)
Mine have been in the van for just over two years now, not one problem. I'm wondering if the newer vans are different or the newer ballasts (yours are different to other that I've seen) are the issue.
Mike
Wind up merchant!
Postby C8XY » Tue Feb 02, 2016 1:10 am
Was hoping they'd work :( anyone recommend a halogen with a bright white output?
My van details:
Primary Features
Build Date: 11.05.2015
Vehicle Line: Transit/Tourneo Custom 2012
Cab Style: Regular Cargo Van
Series: 270S Series
Engine: 2.2L CR TC I4 DSL 125 PS
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.36/3.05
Emission: Stage V LDT3 Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: Panther Black (Metallic)
Interior Fabric: Ecko/Max Charcoal Black
They've been working since, very occasionally they'll bring up the "fault" but haven't actually failed since.
That's probably what it was, it was a cold morning! Possibly the reason it affected the HID too? Maybe it's a temperature thing??
C8XY
Postby arf33 » Thu Feb 04, 2016 1:08 pm
hi all...
these H1 HIR bulbs fresh delivered (this evening...testing):
stay tuned
arf33
Postby arf33 » Thu Feb 04, 2016 2:44 pm
another fresh news...my HID set from HIDS4U is just arrived in office...
this evening many lights upgrading !!! Can't wait ! :D :mrgreen:
arf33
Postby poolie » Thu Feb 04, 2016 3:50 pm
If there for the cornering lamps mate I'll think you'll struggle to fit them in.
poolie
Postby arf33 » Thu Feb 04, 2016 4:09 pm
I will update you about this evening...
I'm confident that will fit...as in the VW golf happen without problems...but...not sure in mine ;)
arf33
Postby arf33 » Fri Feb 05, 2016 12:58 am
yeah....now I have HID headlight !
thanks to FTF (specially Mike) for the suggestion.
tomorrow I will update with pictures
good night
arf33
Postby C8XY » Fri Feb 05, 2016 3:30 am
arf33 wrote:yeah....now I have HID headlight !
good night
Where did you install those other lamps? Did they fit/work?
Cheers
C8XY
Return to Transit Custom
