Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit DO NOT USE 55w KITS
Postby arf33 » Fri Feb 05, 2016 9:22 am
yes the H1 HIR bulbs works... but positive and negative things:
positive:
- no any fitting problems
- no any canbus alarm because are 55w
- light power improvement
- color temperature better than the OEM ones
negative
- color temperature worse than the "tuning" lamps I had already installed (but for sure with less light power)
now I have parking light and low beam with a fantastic 6000k color... and DRL, cornering lights and high beams with warmer color...I will fix it
arf33
Postby arf33 » Fri Feb 05, 2016 1:43 pm
yesterday evening I've upgraded the front light with HID
the HID set used:
installation:
the comparison with tuning H7 bulbs (left side)
full HID
arf33
Postby C8XY » Fri Feb 05, 2016 8:38 pm
Anyone using something like this for the main/drl lamps
http://www.hids-direct.co.uk/mtec-h15-5 ... ade-bulbs/
I'd like Osram but they don't seem to make H15?
They do make an H1 which is the cornering lamps, do these fit?
http://www.hids-direct.co.uk/osram-h1-1 ... twin-pack/
I need the yellow gone!
C8XY
Postby Sparkeselectrical » Fri Feb 05, 2016 9:01 pm
C8XY wrote:Anyone using something like this for the main/drl lamps
They will fit and work, I've fitted xenon bulbs to mine, these are a noticeable improvement over halogen bulbs without the complications associated with the HID option
New 170 Limited 290 L1 DCiV
Sparkeselectrical
Postby Alar » Fri Feb 05, 2016 9:28 pm
arf33, I see you have that dark spot issue in front of the driver like I did
125ps 310LWB Trend Powerty Edition
Alar
Postby jasonx » Fri Feb 05, 2016 9:58 pm
arf33 wrote:yesterday evening I've upgraded the front light with HID
the HID set used
Do you have a link to that set ?
jasonx
Postby arf33 » Sat Feb 06, 2016 12:30 am
Alar wrote:arf33, I see you have that dark spot issue in front of the driver like I did
Hi Alar,
Something dark yes...ok, probably not a big issue...but...
I've my theory:
since the HID bulb have the external connection beside the glass it means that 99% the light beam cannot pass through that slice...so the result is to have one ore more dead area.
I think this is the main problem when the projector is not made in origin for HID lamp (optical and lighting are university matter at those days).
If the headlamp is factory made for HID for sure some engineer fixed this problem with the reflector or something else.
anyway...
this is what I'm talking on:
top view of the HID bulb (sorry for paint)
in this picture easy to see that problem with HID and not with Alogen
double HID bulb...double problem
so I think that some of those black areas are related to:
for example I've read this 3d in one italian forum, unfortunately the pictures are not longer available, but I read it and this guy modified the slot on the bulb base in order to rotate it in a different way, so he described the result as "unbelievable"...I guess it.
click this link
https://encrypted-tbn2.gstatic.com/imag ... XB6L8wdFfN
arf33
Postby arf33 » Sat Feb 06, 2016 12:34 am
the HID set used
this one:
http://www.hids4u.co.uk/h7-35w-ultimate ... n-kit.html
my choice was 6000°K, Projector H7
I can suggest...take the 5000°K...I will probably change mine too...small mistake :)
arf33
Postby jasonx » Sat Feb 06, 2016 12:29 pm
arf33 wrote:
the HID set used
this one:
Thank you :-)
jasonx
Postby poolie » Tue Feb 09, 2016 9:39 pm
I've give in. Mine are getting sent back tomorrow. Been ok for a week or so now instead of knocking power out to one light its blowing fuses :evil:
I've asked for the best H7 bulbs hid look they do and a refund for the difference, which they duly obliged.
poolie
Postby poolie » Wed Feb 17, 2016 6:27 pm
arf33 wrote:hi all...
these H1 HIR bulbs fresh delivered (this evening...testing):
stay tuned
Do you have a link for these cornering bulbs?
poolie
Postby arf33 » Thu Feb 18, 2016 8:57 am
Hi Poolie,
if you want I can sell mine's.
the color temperature do not match the parking light and HID so I want to came back to the previous H1 blue.
let me know
Francesco
arf33
Postby BNObournemouth » Thu Feb 18, 2016 6:52 pm
Does anybody know the location / number and rating of each of the headlamp (LH and RH) fuses at all? The manual does not state anything about them, only a fuse for the 'Cornering Lamp', which is in the Passenger's Compartment Fuse Box, shown as number 30, rated at 20A.
Any help would be awesome, thanks in advance guys :)
BNObournemouth
Postby arf33 » Tue Feb 23, 2016 1:10 am
yesterday I modified the position of the H7 HID bulb in order to have the external connection upside down and minimize the shade caused from.
the tool I used for:
sheet metal scissors
profile copier
the bulb
then in the night I did some test, 1st the shading is not longer an issue...that's good and expected
but...now I see 2 other issues, one is the dark on left and right corners and...the gap between the right and left beam.
about the beam I will try to check better the bulb seating and/or the headlamp installation on the van... but I have no idea how to minimize the dark corners...mumble mumble...
this is the comparison between before and after
before
after
arf33
Postby arf33 » Fri Feb 26, 2016 9:41 am
hi all...
I've fixed the misalignement issue...it was the headlight not propely seated...1 minute job.
bye
arf33
Return to Transit Custom
