Radiator fan trying to spin HI but fails
Re: Radiator fan trying to spin HI but fails
Postby Kardaani » Thu Jul 14, 2022 8:12 am
Resistance is so small it´s impossiple to relibly measure with multimeter. Figured it out with Ohm´s law but i cant remember the result. Below one ohm it was. Might be 0,6 Ohms but not sure.
Kardaani
Postby smellmyflower » Thu Jul 14, 2022 8:45 am
Kardaani wrote:Resistance is so small it´s impossiple to relibly measure with multimeter. Figured it out with Ohm´s law but i cant remember the result. Below one ohm it was. Might be 0,6 Ohms but not sure.
Perfect. Many thanks.
smellmyflower
Postby gregd72002 » Wed Jul 12, 2023 10:43 pm
Same problem on mine as of today. Do I try to source right resistor? Or rather get it off and try to fix it?
But what’s the procedure to get it off and do the fix?
Cheers
gregd72002
Postby gregd72002 » Fri Jul 14, 2023 10:58 am
Problem fixed. Got broken wire too and re-wired with a resistance wire. We calculated that the original resistance was around 0.25 Ohm.
It works fine.
Anybody knows what is the small component (diode?) that runs across the ends of the resistor, and what is its purpose?
gregd72002
Postby metalworker0 » Fri Jul 14, 2023 1:01 pm
Probably for back EMF
Postby John_boy » Sat Aug 03, 2024 2:43 pm
gregd72002 wrote:Problem fixed. Got broken wire too and re-wired with a resistance wire. We calculated that the original resistance was around 0.25 Ohm.
It works fine.
Hi, how did you attach the new wire and did you leave the wire exposed after wrapping it around the ceramic tube?
What diameter resistance wire did you use?
any help would be appreciated
John_boy
Postby John_boy » Sun Aug 11, 2024 4:05 pm
It works fine.
Hi, how did you connect the new resistor wire after snipping off the old wires?
John_boy
Postby Kardaani » Sun Mar 16, 2025 6:23 am
Long time no see, but I used these crimp ferrules and ferrule pliers with that to connect new resistor wire to old ones. Works fine, the steelwire has burned out once after repairing but not from the connection point.
https://copper-terminals-lugs.brass-par ... ules-1.jpg
Other crimp-style ferrules works also fine, i think. Connectors for steel wire rope for example.
Kardaani
Return to Transit Custom
