Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit DO NOT USE 55w KITS
Postby seikokid » Mon May 16, 2016 10:56 pm
So I've bought all my LED bulbs from HID4U, I am having problems also with the brake light. It brings up a bulb fault once when the van is started but not again until I restart the van.
Where did you get your leds from please and have it also fitted the brake / tail leds with / without problems ?
Whilst I'm on this I have the 35W stealth HIDS for the dipped beam. They are giving me the issue that requires a wiring loom to be installed and connected to the battery. Is there another way round this / another brand I can use ?
seikokid
Postby seikokid » Fri May 20, 2016 10:27 pm
HIDs connected up with the loom , 1 side worked fine but the other flickered, worked ok but not as bright then stopped working . After a reset it worked again but flickering to start and not full bright
Too much hassle , going for brighter standard H bulbs hassle free
Still waiting for Phillips indicator lamps to arrive . I'm curious to see if just using the higher wattage resistor cures my problem. HID4U supply 10 & 5 w so might need something higher ?!?
Reverse , Rear fog , number plate and top brake light LEDs working perfectly
Tail works fine , brake brings up fault on first use then not until van is restarted
Indicators flashing fast rate but work normal on hazard
seikokid
Postby seikokid » Wed May 25, 2016 10:18 pm
[/quote]
I fitted the Philips xtreme led indicator bulbs, they come with the can bus cancellers. No idea how they're controlled though.[/quote]
Mike, where did you fit the resistors on the front indicators please ? at what point did you clip into the loom ?
Do you have any photos please ?
I've bought and fitted the Phillips to the rear and they are working well , brighter than the HID4U LEDs
seikokid
Postby seikokid » Sun May 29, 2016 12:29 pm
All done , clipped the resistors into the loom within the headlight and fastened the resistors on top of the headlight housing using aluminium tape.
seikokid
Postby ravin beef » Mon Oct 31, 2016 10:14 pm
http://www.hids4u.co.uk/h7-35w-ultimate ... n-kit.html
Are these still the weapon of choice?
They have changed the ballasts to 'stealth', does anyone have any experience with these new kits?
ravin beef
Postby seikokid » Mon Oct 31, 2016 11:08 pm
i sent mine back as it ended up looking like a spiders web under the bonnet. One ballast didn't work properly and the resistors got way to hot for my liking . I chose some bright lamps and bright fogs instead and are much happier for it
seikokid
Postby mavericktc » Mon Oct 31, 2016 11:54 pm
Has anyone tried leds for the dip beam?
From what I see in the manual dip beam uses a H7 socket.
Can you use this?
http://www.hids4u.co.uk/H7-Twenty20-Cre ... -Bulb.html
Or does the beam get completely destroyed?
mavericktc
Postby Mike » Tue Nov 01, 2016 8:36 am
mavericktc wrote:Has anyone tried leds for the dip beam?
viewtopic.php?f=65&t=152479
Mike
Wind up merchant!
Postby ravin beef » Thu Nov 03, 2016 9:38 pm
Just ordered the 35w 5000k kit, £55.96 delivered.
Not a bad deal :)
ravin beef
Postby ravin beef » Mon Nov 07, 2016 10:36 pm
Evening fella's, received my kit today and fitted it tonight.
Then took it out again as I now have 'dipped beam fault' and will have to make a trip past the dealer in the morning.
I'll see what HIDS4U are saying in the morning too.
ravin beef
Postby seikokid » Mon Nov 07, 2016 11:35 pm
did you fit the resistors ?
seikokid
Postby John Johnson » Tue Nov 08, 2016 9:41 am
I've just put a set of the new Phillips rally vision in , excellent and no faults :D
John Johnson
Postby Mike » Tue Nov 08, 2016 7:13 pm
Mike
Wind up merchant!
Postby ravin beef » Tue Nov 08, 2016 8:55 pm
seikokid wrote:did you fit the resistors ?
There weren't any resistors to fit fella, they claimed the ballasts are can bus compatible - which they are definitely not.
ravin beef
John Johnson wrote:I've just put a set of the new Phillips rally vision in , excellent and no faults :D
You sure they are 'rally'?
Are they not 100w?
ravin beef
Return to Transit Custom
