Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit DO NOT USE 55w KITS
Postby arf33 » Tue Jan 10, 2017 1:05 pm
yesterday also my RH lamp is gone!
now I'm without headlight.
I hope that HIDS4U will replace in warranty, I'm sending an email
:? :cry:
arf33
Postby arf33 » Mon Jan 16, 2017 9:59 am
keeff wrote:Test for power before the HID kit if it is dead then you could be looking at getting the ecu reset at the dealers . I had this with mine as the ecu had some sort of built in electronic cut out gone are the days of just a fuse.
Sent from senderPhone using Tapatalk
In fact.
Yesterday I tested the HID on the bench with 12v supply power and it work pproperly. On the other hand I put a normal HD bulb in the van and doesn't work. So it means that, as you said, there is a power cut from electronics.
By the way I already contacted HIDS4U and they told me that now they are replacing the ballast with version 2 because many custom owners are getting similar problem. They can replace under warranty, so I'm in doubt if reset Ecu and keep these ballast or send back for replacement
arf33
Postby arf33 » Mon Feb 06, 2017 4:41 pm
I sent back the ballast to HIDS4U, they will give me back the latest version.
by the way I decided to sell the van, so I will use them in the next van
arf33
Postby Veki007 » Wed Feb 08, 2017 8:20 pm
In fact.
I had that problem again couple days ago luckily i live 2 minutes from vantuner so he was able to clear code in 10minutes without going to ford.But that is happening on newer fords and when batter is not new anymore.
Veki007
Postby arf33 » Thu Feb 09, 2017 10:10 am
I went to my near mechanics, in 5 minutes they reset the alarm too.
but since I will sell my Tourneo I fitted again the standard bulbs
bye
arf33
Postby arf33 » Mon Feb 20, 2017 12:27 pm
new ballast from HIDS4U just arrived.
I will try them on next van for sure.
bye
Francesco
arf33
Postby radioman6923 » Fri Jun 16, 2017 6:07 pm
I have a 2016 Ford Transit Connect XLT here in the USA. Do I need Canbus ballasts for my HID kits?
Sent from my SM-G950U using Tapatalk
radioman6923
Postby Mike » Fri Jun 16, 2017 6:21 pm
radioman6923 wrote:I have a 2016 Ford Transit Connect XLT here in the USA. Do I need Canbus ballasts for my HID kits?
FFS, I've already told you once,
Mike wrote:The 55w kits draw too much current at start up. There's a thread in the Custom section about hid's, all the info you'll ever need.
Mike
Wind up merchant!
Postby radioman6923 » Fri Jun 16, 2017 6:29 pm
They have 35w canbus ballasts...i need to know if I need a canbus ballast or not. Some vehicles have a canbus electrical system so the ECM can see if a light is working or not
radioman6923
Postby Mike » Fri Jun 16, 2017 7:19 pm
radioman6923 wrote:They have 35w canbus ballasts
Not what you said on your other thread?
radioman6923 wrote: I've tried the harness with anti flicker capacitors and 55w slim ballasts...........Today I tried just a direct hook up..no harness and used 55w canbus ballasts but still they did not ignite.
Anyway, yes you need can bus ballasts and a 35w kit..........it MIGHT work, no guarantees.
Mike
Wind up merchant!
Postby radioman6923 » Tue Jul 11, 2017 5:43 am
I got the 35w canbus ballasts and they failed to work which is really disappointing! Not sure why they won't work for my van?
radioman6923
Postby Mike » Tue Jul 11, 2017 7:54 am
radioman6923 wrote:Not sure why they won't work for my van?
HIDS4U kit?
Mike
Wind up merchant!
Postby Ryanjones0143 » Tue Jul 11, 2017 11:18 am
I've got a HIDS4U kit sitting in the garage.
I'm just not sure wether I should risk fitting it to my 17 custom or not??
Any ideas?
Ryanjones0143
Postby S60r » Tue Jul 11, 2017 11:00 pm
no
S60r
Postby radioman6923 » Wed Jul 12, 2017 12:27 am
HIDS4U kit?
Do I need this type of kit for them to work on my car? I bought my kits online at xenonhids.com but the connections with my factory harness were crappy and would not lock in place. I had to use electrical tape to keep the connection from coming apart. They are taking their sweet time getting me an RMA
radioman6923
Return to Transit Custom
