Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit DO NOT USE 55w KITS
Postby Levo » Fri Oct 11, 2019 10:10 am
Thats funny, I just visited this site and popped in my details (Custom 2015 ) and it said we don't have parts for this vehicle?
Levo
Postby tompenny » Wed Jan 01, 2020 10:17 pm
I have tried to install HID and LED headlight low beam with absolute dramas! Both types caused my CANBUS to go on overdrive which resulted in tripping the Body Control Unit. This in turn had to be 're-set' by FORD at the obvious ridiculous cost. Any one having the same issue on their Custom?
tompenny
Postby ROR1J » Sat Sep 12, 2020 6:07 pm
Sorry to revive an old thread here, wish i'd of read this last month, i'm now without a headlight as it's tripped the system, i've read through the thread but can only work out that i have to go to ford for a reflash :(.
will an auto technician be any cheaper do we think? Also my van got re-mapped recently too. will this wipe my map off?
Cheers
ROR1J
Postby Mike » Thu Sep 17, 2020 8:21 am
tompenny wrote: Any one having the same issue on their Custom?
Have you read the thread? If you have then you need to post more details of what you've installed as we can't afford the batteries for our crystal ball.
Mike
Wind up merchant!
Postby ROR1J » Thu Sep 17, 2020 9:18 am
GOOD NEWS, my local garage managed to reset the BCM with his OBD reader, £20 job no need to pay £100's to Main Stealers.
ROR1J
Postby Gravstein » Thu Apr 08, 2021 5:49 pm
I have had good luck with these ones, 3 weeks and no Bcm shut off or bulb warnings.
Bulbs im using are Morimoto H7 4300k and it's a blast to drive in the dark!
https://www.xenonkungen.com/no/produkte ... w-40w.html
Potato phone, but you get the idea
Gravstein
Postby sherwoodcycles » Wed Mar 27, 2024 9:49 pm
Following this thread, I got a couple of projector lights and the 5k 35w hids4u set. I find the light very greeny/blueish. I prefer the original yellow colour light. I'd not mind if it was whiter but it's that it's greeny that I'm not keen. Hids4u have been great in responding to my moan, they suggest changing to 50w ballast but I don't want my bcm having trouble. I can reset it. But I'd rather not have to.
Has anyone tried LEDs from them ? I'm wandering if that would be a better colour?
Greeny
sherwoodcycles
Postby sherwoodcycles » Fri Nov 29, 2024 6:13 pm
Fitted my originals back in now (halogen reflectors).
If anyone is thinking of trying HID, you can buy mine. Massive let down trying them. But you got to try these things. I only had the occasional warning trip. Apart from that, they worked well. Just a bit overatted in my opinion..
Greeny
sherwoodcycles
Return to Transit Custom
