Upgrading the door speakers
Re: Upgrading the door speakers
Postby TallPaul » Fri Nov 14, 2014 8:05 pm
I just did this today and fitted the Focal 165's, I found 9 fixings holding the panel on...
Being the cheapskate that I am, I couldn't stretch to Dynamat so instead I used roofing flashing tape- cost a tenner!
I did have one problem though, not being too clued up on the world of stereos, the speakers are marked + & - but how do I know which are which on the van loom? I tried them both ways and to be honest, I couldn't really tell much difference!
TallPaul
Postby Tran59 » Fri Nov 14, 2014 8:44 pm
Nice job. That screw right at the top is a real bugger to get out.
The problem with using roof flashing in cars is that it eventually dries, cracks and then falls off. It can also smell a bit in the summer. Dynamat uses butyl rather than bitumen to avoid this.
The best mods are the ones you don't see
Tran59
Postby TallPaul » Fri Nov 14, 2014 9:00 pm
Tran59 wrote:Nice job. That screw right at the top is a real bugger to get out.
I've never used that flashing before, but had seen someone else suggest it on another forum so I'll let you know how it fairs during next summer...
The top screw is actually pretty easy, you just need to take out the window switch first, then its very easy to get on it!
TallPaul
Postby Tran59 » Fri Nov 14, 2014 11:28 pm
Aha, missed the window switch trick. Thanks :)
Tran59
Postby BringTheRain » Sat Nov 15, 2014 12:19 am
BringTheRain wrote:
Altransit wrote:
BringTheRain wrote:Been out to fill up with diesel and the sounds is more crisp and clear. The quailty is superb.
It lacks in Bass really and that's the main sore point!
Are you sure that you didn't end up putting the positive wire to the wrong tag on one of the speakers :?: Lack of bass is a classic symptom of "out-of phase" speakers :wink:
No i used the 9v battery trick to test if the speaker pops out or sucks in :)
https://www.youtube.com/watch?v=xIMHGkxw72o
BringTheRain
Postby TallPaul » Sat Nov 15, 2014 8:26 am
BringTheRain wrote:
BringTheRain wrote:
Altransit wrote:Are you sure that you didn't end up putting the positive wire to the wrong tag on one of the speakers :?: Lack of bass is a classic symptom of "out-of phase" speakers :wink:
Yes I saw that but although the new speakers have the positive and negative marked, theres nothing to differentiate the wires from the van.
TallPaul
Postby TallPaul » Sat Nov 15, 2014 8:30 am
I'm not sure whats going on with the forum clock but I'm posting this at 7:30am on saturday 15/11/2014!
TallPaul
Postby yasser » Sat Nov 15, 2014 9:04 am
TallPaul wrote:Yes I saw that but although the new speakers have the positive and negative marked, theres nothing to differentiate the wires from the van.
Can you not turn the radio on and the put a volt meter on the ends to earth and see which one is supplying the feed. that will be the POS.
310 DCiV L2 Limited 155
yasser
Postby TallPaul » Sat Nov 15, 2014 9:35 am
That would make sense, I'll give it a try later...
TallPaul
Postby ake » Sat Nov 15, 2014 12:55 pm
TallPaul wrote:I'm not sure whats going on with the forum clock but I'm posting this at 7:30am on saturday 15/11/2014!
You need to correctly set your time zone in board preferences
Postby BringTheRain » Sat Nov 15, 2014 6:39 pm
After watching the video, i understood how a speaker works. So when i connected my new speakers i could watch if it was correctly wired or not. As it happens they were not wired correctly.
BringTheRain
Postby AllAboardTheWolfBus » Mon Dec 15, 2014 11:58 am
Just to check, 165mm are 6.5" speakers? If so, yay! I have a set kicking around looking sorry for themselves.
Has anyone replaced the stock tweeters?
AllAboardTheWolfBus
Postby newbie89 » Fri Jan 23, 2015 4:26 pm
Cheers for this thread guys. Most helpful!
Planning my speaker install this weekend, so will, update when done. Lots of useful info here.
Also replacing the factory tweeters. So to the guy above what do you want to know?
Regards
Martin
newbie89
Postby AllAboardTheWolfBus » Wed Jan 28, 2015 12:51 am
newbie89 wrote:Also replacing the factory tweeters. So to the guy above what do you want to know?
How did you get on?
The main things I wondered about were:
1. do I need to worry about crossovers or are there already factory ones?
2. Do I need to buy a specific size? Will they fit easily or need to be hot glued in or similar?
3. Is it even worth bothering with?
Since we're here, an open question - I'm planning on installing a sub to reinforce the low end, and I'm going to use the front speaker wires as the source (my amp has speaker level inputs). Has anyone tapped in to the stock speaker wiring like this before? Any gotchas I need to be aware of or tips?
AllAboardTheWolfBus
Postby Mike » Wed Jan 28, 2015 1:30 am
I'll be chucking this lot in the van in about 10days time, if you can wait viewtopic.php?f=27&t=140683&start=60#p1272994
Mike
Wind up merchant!
Return to Transit Custom
