Automatic climate control set
Re: Automatic climate control set
Postby jasonx » Sun Oct 19, 2014 6:37 pm
BRAVO9992 wrote:Has anyone had this fitted in the uk?
Yes, there is RHD version of this automatic climate control set - check: https://www.fordshop.cz/sada-pro-domont ... kopie.html . It is completely the same solution as for LHD. There is only one change - frame is adapted to the RHD.
jasonx
Postby Meyer automotive » Sun Oct 19, 2014 10:09 pm
Mine is also fitted, works perfect!! And was very easy to install.
Ford transit Custom, 270 125 hp L1H1 double cab fully loaded, lowered, chipped 190 hp, egr and dpf off, 487 nm torque. And special design leather interior grey with black piping and stitches.
Meyer automotive
Location: In car electronics, in house LED light specialist, domotics
Postby Trasher83 » Mon Oct 20, 2014 10:02 am
fordshop wrote:
Rossi, tomorrow we will install the set into an older car and see if it is possible to install the set (with full functionality) into older cars. We will let you know about tomorrow's results.
Petr
Did you get it to work? I have a Sport built 4/2013 and was considering getting this set.
Trasher83
Postby Tran59 » Mon Oct 20, 2014 10:51 am
Meyer automotive wrote:Mine is also fitted, works perfect!! And was very easy to install.
My dealer is installing mine as I type. When you say it was easy to fit, can you be more specific? Did you do it yourself? How many man-hours is my dealer likely to charge me tonight?? :? TIA
The best mods are the ones you don't see
Tran59
Postby Tran59 » Mon Oct 20, 2014 5:00 pm
Bloody hell, went to collect the van at the dealer's tonight and it wasn't ready. They said it had been a difficult job and they needed an hour or so extra to put all the dash together again. I hope they're not going to present me with a massive bill tomorrow :oops:
Tran59
Postby Mike » Mon Oct 20, 2014 5:19 pm
Tran59 wrote:Bloody hell, went to collect the van at the dealer's tonight and it wasn't ready. They said it had been a difficult job and they needed an hour or so extra to put all the dash together again. I hope they're not going to present me with a massive bill tomorrow :oops:
Sounds like you went to Perrys in Aylesbury!
Mike
Wind up merchant!
Postby Meyer automotive » Mon Oct 20, 2014 9:38 pm
It took me two hours, I did it myself in the same time I installed my brodit mobile holder charger. The most difficult was to get the upper part of the dash, were the display is in, fitted because the upper temperaturesensor was pushed out because of a part of the inner dash was in the way.
Meyer automotive
Postby Transloco » Mon Oct 20, 2014 10:36 pm
Meyer automotive wrote:It took me two hours, I did it myself in the same time I installed my brodit mobile holder charger. The most difficult was to get the upper part of the dash, were the display is in, fitted because the upper temperaturesensor was pushed out because of a part of the inner dash was in the way.
Does'nt iT need à software update?
Transloco
Postby BRAVO9992 » Tue Oct 21, 2014 12:02 am
great news mate, now i know someone has fitted it themselves i'll order one
BROWNWIRE ELECTRICAL
290,155,L1,MidnightSky,Limited
BRAVO9992
Postby BRAVO9992 » Tue Oct 21, 2014 12:03 am
have you got any photos where you had to drill the hole behind the display?
BRAVO9992
Postby Tran59 » Tue Oct 21, 2014 9:02 am
Transloco wrote:Does'nt iT need à software update?
I was wondering the same. How did you get round the software problem... or isn't there one??
Tran59
Postby BRAVO9992 » Tue Oct 21, 2014 12:13 pm
Apparently its only earlier models that need software updates, before you order the kit, message the company and they will check your vin number
BRAVO9992
Postby Tran59 » Tue Oct 21, 2014 1:10 pm
BRAVO9992 wrote:Apparently its only earlier models that need software updates, before you order the kit, message the company and they will check your vin number
OK, thanks. My Sport is a Sept 2013 build, so they had to update the software. I was charged 5.5 hours labour, so the final bill, including the new control unit, came to about £450 + VAT.
It's nice to use, though weirdly it doesn't quite match the look of the rest of the dash...as if it came from another Ford model. I would also have preferred it without the chrome strip across the top, but I can always wrap that in a bit of black vinyl. Not today though, cos it's blowing a gale :?
Incidentally, I don't see why this won't fit RHD vehicles. The manual unit they took out is good for both R & LHD. It's really just the big black plastic trim part that's specific to the UK, because the 12V socket is on the other side.
Tran59
Postby Alar » Tue Oct 21, 2014 1:17 pm
The only thing that does not seem to match is the black plastic around it
125ps 310LWB Trend Powerty Edition
Alar
Postby Mike » Tue Oct 21, 2014 4:45 pm
Does it take tapes or cd's? :mrgreen:
Mike
Wind up merchant!
Return to Transit Custom
