240V inverter
240V inverter
Postby TallPaul » Fri Nov 29, 2013 8:48 pm
Has anybody got the Ford power inverter by the handbrake, whats it like, would it power a 4inch angle grinder (for cutting tiles etc) or is it only suitable for charging phones & laptops?
Failing that, has anybody used these type, VKTECH 1000W INVERTER
TallPaul
Re: 240V inverter
Postby dan_robinson » Fri Nov 29, 2013 10:26 pm
Factory option is only ~130W so not much good for tools.
dan_robinson
Re: 240V inverter
Postby DrDeAtH » Sun Dec 01, 2013 5:37 pm
You could charge an 18vcordless drill battery off of it. Maybe power a laptop.
DrDeAtH
Re: 240V inverter
Postby Jamesg5206 » Sat Dec 14, 2013 6:53 pm
Does anyone if it is possible to get the 240 inverter fitted by the dealer after delivery. Mines still on order but what with a delivery date in January, I'm thinking its a late in the day to get it add as an extra. Only thought it would be useful when my battery drill went flat when I was working next to my van.
Transit Custom 125 Trend SWB Panther Black 2014-2017 Transit Tourneo Custom 185 Agate Black Titanium X LWB 2019-
Transit Tourneo Custom 155 Titanium LWB Panther Back 2015-2019
Transit Custom 170 Limited SWB Shadow Black 2017-
Jamesg5206
Re: 240V inverter
Postby DrDeAtH » Mon Dec 16, 2013 10:13 am
Ask the dealer....
Other than that, fit your iwn
DrDeAtH
Re: 240V inverter
Postby V184 » Mon Dec 16, 2013 9:18 pm
Jamesg5206 wrote:Does anyone if it is possible to get the 240 inverter fitted by the dealer after delivery. Mines still on order but what with a delivery date in January, I'm thinking its a late in the day to get it add as an extra. Only thought it would be useful when my battery drill went flat when I was working next to my van.
If you do find a dealer capable of fitting one please post there name up as i would be amazed !
V184
Re: 240V inverter
Postby TallPaul » Mon Dec 16, 2013 11:01 pm
I havent taken the handbrake trim off but my guess is the wiring is already there and it'd be a pretty simple plug & play...
TallPaul
Re: 240V inverter
Postby Jamesg5206 » Mon Dec 16, 2013 11:39 pm
That's just what thinking.
That's what I think will be the problem.
Jamesg5206
Re: 240V inverter
Postby Malc6552 » Tue Dec 17, 2013 12:16 am
I have the inverter and was told I have additional 12volt battery located under driver seat as the power source for the inverter .... Hope that helps anyone looking to retrofit
Malc6552
Return to Transit Custom
