Very straightforward installation using the HIDS4U.co.uk kit that Mike kindly gave me the heads-up on. No relays, no wires to the battery, just plug & play... well, almost. Going very slowly and carefully, it took me about 1 hour to fit the first side, but only about 15 minutes to do the second, as I knew what I was doing. I removed the headlights (very easy, just two bolts) to improve access.
Also fitted an LED parking bulb (top left of xenon light in the photo) to match the HID. Thanks again to Mike for advising me to go with the Osram model.
The photo was taken half way through in very bright spring sunshine (at last!!), so not the best quality, but you can see the difference between the two headlights: xenon on the left, Osram Nightbreakers (which were already a bit better than the factory issue H7s) on the right.
