Transit custom limited delivered this week :)
Postby 7up_elise » Sat Jan 31, 2015 7:42 pm
So after a massive palava with vanarama, my new custom limited finally arrived Thursday!
First impressions of the van are brilliant! Coming from a mk6, there's obviously no comparison, but I'm over the moon with it so far!
Today I ply lined the rear to remkge that ghastly floor protector, and gave her a good clean as she had traveled 200 miles to be delivered!
Just a couple of questions, does this model have stop start? If so do I need to turn it on somehow?
Also I noticed whilst flicking through the manual that nothing has been stamped in the book regarding the dealer?
Surely there should be a dealer stamp in there and the warranty bit should be filled out?
Other than those queries which I need to chase up,I absolutely love it!
7up_elise
Re: Transit custom limited delivered this week :)
Postby 7up_elise » Sat Jan 31, 2015 7:48 pm
7up_elise
Postby deno 1 » Sat Jan 31, 2015 8:04 pm
If its got stop start it will be on all the time unless you switch it off every time you start the van up...
The switch is to the right of the main clocks......next to the parking sensor switch.....its marked ECO
deno 1
Postby 7up_elise » Sat Jan 31, 2015 8:33 pm
Ah okay,so it definitely doesn't have it then :) cheers for the advice!
7up_elise
Postby Tran59 » Sat Jan 31, 2015 10:31 pm
7up_elise wrote:Ah okay,so it definitely doesn't have it then :) cheers for the advice!
Think yourself lucky, the Eco mode/button is a pain in the a$$ :?
The best mods are the ones you don't see
Tran59
Postby Tiny01 » Sat Jan 31, 2015 11:42 pm
Tran59 wrote:Think yourself lucky, the Eco mode/button is a pain in the a$$ :?
Curious to know why you say that ?
Tiny01
Postby The transporter » Sat Jan 31, 2015 11:52 pm
Hi Tiny,
I too have ordered through Vanarama, what issues have you had?. They did seem to be pretty well organised and on the ball. Also they said that my van would come with ply lining... Was this not the case for you?
VW Commecial Vehicles.....Lets Walk to Work.
The transporter
Postby Altransit » Sun Feb 01, 2015 12:08 am
If it's anything like the system on my sons' VW Caddy, it has an alarming habit of stopping just as you are about to pull out into a busy road :shock: You have to make a conscious effort to keep your foot on the accelerator to stop it happening :roll:
Postby Mussels » Sun Feb 01, 2015 12:12 am
The transporter wrote:Hi Tiny,
I found ordering through a main dealer a painful and rubbish service, Vanarama can't be much worse.
Mussels
Postby The transporter » Sun Feb 01, 2015 12:21 am
The only real issue so far is the long delivery time but I have a van that works just fine so that isn't an issue with me, ordered it by email, paid deposit by debit card... As long as it comes with a tow bar, pop up toast rack on the roof and painted in Jewish racing gold....Sorry, Tectonic silver, then I'm a happy bunny
The transporter
Postby deno 1 » Sun Feb 01, 2015 1:04 am
Curious myself .......wots the accelerator got to do with the stop start????
deno 1
Postby The transporter » Sun Feb 01, 2015 1:50 am
I'm curious, how do these stop start thingies work? does it have a motor built into the flywheel like Renault tucks had to ensure a smooth pull away or does it rely on the starter motor like Fiat tried in the eighties
Not at all sure that I like the idea of a starter motor engaging all the time in start stop traffic
The transporter
Postby Tran59 » Sun Feb 01, 2015 10:04 am
I was referring to the power limiter when you're driving. I had a base Custom on loan for a few weeks while I was waiting form my Sport and every time I wanted to overtake or go above 60, I had to switch the bloody Eco mode off.
Tran59
Postby Altransit » Sun Feb 01, 2015 10:10 am
deno 1 wrote: Curious myself .......wots the accelerator got to do with the stop start????
I'm talking about a Caddy, but I'm assuming the system on the Custom is similar ................................
If you come up to a junction, and sit with your foot on the brake, the engine will stop after a few seconds, and re-start when you press the throttle. If you remove your foot from the brake before the engine stops, and press the throttle to fast idle, the engine will stay running.
It's OK if you remember to do it, but can be a bit scary when the engine stops just as you are about to pull on to a busy road :!:
Postby 7up_elise » Sun Feb 01, 2015 10:22 am
My wife's smart had stop/start and I remember that took some getting used to! Certainly made you think twice about pulling out of junctions! But then again the smart wasn't really that good at anything... Lol! Although she did love it!
The van did come with 'ply lining' fitted, but this was literally 2 bits of ply either side, and the wheel arches boxed. The rest was the standard ford hardbord panels. I have now fitted and carpeted over the top of the floor liner as it was good for nothing!
Yet to rack it, but until the sun comes I can live with just the floor being done!
7up_elise
Return to Transit Custom
