Key fob failure
Key fob failure
Postby Bull Bus » Mon Nov 23, 2015 4:33 pm
Has anyone else had their key fobs fail? My fob wouldn't unlock or lock the doors this morning, and when I manually unlocked the doors it set the alarm off.
When the key is in the ignition, the alarm stops, and the van will start as normal. Tried the spare fob (which is never used normally), and that didn't work either).
Rang the stealers, and they suggested the battery needed changing. The van is only six months old so I'd be surprised if it was the battery. Anyway, looked in the manual and can't see any instructions on battery changing. The keys are self-charging I believe, so I doubt that it's recommend for the user to change batteries.
Can anyone confirm whether the batteries are replaceable, and has anyone had similar issues with their fobs? Any solutions?
Thanks in anticipation.
2015 Custom SWB DCIV 125 Limited
Bull Bus
Key fob failure
Postby Alar » Mon Nov 23, 2015 4:37 pm
I've had the van for 1,5 years and have used only one key and it still works fine. I can unlock/lock the car from 30-40meters
Still has the original battery
125ps 310LWB Trend Powerty Edition
Alar
Re: Key fob failure
Postby Treespotter » Mon Nov 23, 2015 6:58 pm
Can't be the batteries on both key fobs. Usually these batteries last more than three years when in daily use. It looks like you need to search in the antenna and not the sender.
Treespotter
Re: Key fob failure
Postby Mussels » Mon Nov 23, 2015 8:21 pm
Treespotter wrote:Can't be the batteries on both key fobs. Usually these batteries last more than three years when in daily use. It looks like you need to search in the antenna and not the sender.
What are the odds the dealer will make him buy new fobs before they will accept there may be a fault with the van? That will also be after they try to blame his home WiFi and sunspots first.
Mussels
Re: Key fob failure
Postby Mike » Mon Nov 23, 2015 8:53 pm
The rechargeable battery should last years and I'm certain that both of them wouldn't fail at the same time.
Mike
Wind up merchant!
Re: Key fob failure
Postby Bull Bus » Tue Nov 24, 2015 6:54 pm
Thanks for the replies guys. Strangely, when I went to the van this morning, the fob worked fine and has been all day.
One of those things, I guess.
Bull Bus
Re: Key fob failure
Postby Mussels » Tue Nov 24, 2015 9:34 pm
I used my spare for the first time today after it sat in a drawer for a year and it worked fine.
Mussels
Re: Key fob failure
Postby Bull Bus » Thu Dec 03, 2015 11:19 am
Started playing up again - booked back in the dealer to be looked at. I'll bet it'll start working fine again just before I get to the workshop....
Bull Bus
Re: Key fob failure
Postby Mussels » Thu Dec 03, 2015 3:37 pm
Does it only happen in one place? Wondering if it could be interference, I once had a lightbulb which would mess with the TV remote when it was on. I'd hope key fobs are more advanced but if something nearby is emitting enough power it will throw it.
Mussels
Re: Key fob failure
Postby bat666x » Mon Aug 06, 2018 5:27 am
I have too had the same fault with the bull bus, came out on Thursday morning and nothing. Tried the other fob this too was no good :cry:
I got in with the hykee key and opened all doors but found the liftgate would not open. I suspected this to be the problem as I had 4 spare wheels in the boot and one of them had moved and was pushing on the tailgate, a quick run up the road with some emergency stops cured the problem. When I eventually got the tailgate opened I could see on my newly carpeted panels where the wheel had been forcing against the rear door. Lesson learnt :oops: tie down any loose luggage in the rear compartment before driving off.
bat666x
Re: Key fob failure
Postby Altransit » Mon Aug 06, 2018 4:39 pm
Does this van have two batteries under the seat?
Re: Key fob failure
Postby Marcus123 » Tue Aug 07, 2018 6:34 pm
Is it nescessary to use both keys from time to time so the uncharged one doesn't die all together ??
Marcus123
Re: Key fob failure
Postby bat666x » Sun Aug 19, 2018 3:35 pm
Sorry Altransit,
I have just seen your reply, yes it is fitted with the 2 batteries under the drivers seat.
bat666x
Re: Key fob failure
Postby Altransit » Sun Aug 19, 2018 4:40 pm
bat666x wrote:Sorry Altransit,
Your auxilliary battery may be failing, and needs replacing.
I think that it's the rear one in a Custom (It's the front one in a Mk7!)
Return to Transit Custom
