ethrty wrote:Mine had a water deflecter fitted last time i was in for a service. I went to pick the van up and suprised to find the headlight out, they were just putting it in as i arrived, they said they had just fitted the update part. They also replaced a few of the terminals for free as well.
Jvic28 wrote:Hi folks. There is an water ingress recall might be worth checking if you need it. Get it free then
Flatfour1 wrote:I have only fitted this to the near side to protect the ECU and so far the whole area does stay dry.
All it is is a couple of sheets of self adhesive sound deadening material ( sourced from eBay for another project ) that are stuck to each other then to the rear of the bulkhead and inner wing.
When the weather warms up and dries out a bit I am going to put a small amount of black silicone sealant on the lower 3/4 cm of the channel to the lower end of the front screen and try and deflect the water from this ' gap' onto the bottom of the screen and into the plastic scuttle and away via the correct ducts.
